clunking noise in frnt end.
Old Nov 21, 2006 | 08:26 PM
extensioncordy's Avatar
Default clunking noise in frnt end.
i have heard it before. but today it got extremly bad. its not an axle sound its like a knock or a thump. its only when i brake , shift or let off the gas. it sounds like its only Coming from the Front right. any help appreciated
cars a 91 std
Old Nov 21, 2006 | 08:45 PM
Iron_Forrix's Avatar
id like to know aswel. i just had a full swap done. and i here a clunking or thumping sound from the fron of my car as i drive. i even feel. mostly when im acelerating, turning, free driving (clutch fully pressed).
would like some suggestions for a remedy.
sorry for no help. my prob as well
Old Nov 21, 2006 | 08:57 PM
88crx-si's Avatar
if you say its not an axle sound and its like a knocking or thumping sound, then you should check out your motor mounts. it might also cause harder shifting and knocking sounds when revving the engine or even turning. good luck
Old Nov 22, 2006 | 12:17 PM
so i take it al apart today and find a bad upper balllll joint and think ahh got it... replaced it and it stil did it... every motor mount was loose.... problem sovled
Old Nov 22, 2006 | 12:23 PM
Tyson's Avatar
Default Re: (extensioncordy)
hmm yeah, seems pretty consistent that clunkiness during acceleration and braking are due to motor mounts or a broken subframe.
glad you got it fixed. hopefully this helps others.
ftrms
Dec 8, 2009 03:36 PM
accord_raffi
Jan 26, 2009 03:34 PM
civic nut
Apr 14, 2005 01:28 PM
Acuraman420
Jul 1, 2004 11:41 AM
