Crome users: What is your target idle?
Old Nov 21, 2006 | 07:48 PM
GetawayInMoscow's Avatar
Default Crome users: What is your target idle?
I'm just curious to see what you have your target idles set at.
I want to raise mine to 850 because of my lightweight flywheel and CTR crank pully...
Old Nov 22, 2006 | 01:55 AM
b19coupe's Avatar
Default Re: Crome users: What is your target idle? (GetawayInMoscow)
It varies from setup to setup. Stockish cams like ~750-850. Bigger cams like Toda B, C and Skunk Pro series cams want 900-1000. Just remember to go to the advanced tables and change your idle settings there as well.
Old Nov 22, 2006 | 02:29 AM
an2ny888's Avatar
Default Re: Crome users: What is your target idle? (b19coupe)
i find that setting target idle in crome doesn't really work on my setup, i usually have to fiddle with the throttle screw
Old Nov 22, 2006 | 03:19 AM
koczeka's Avatar
850 (both set in options and advanced tables), idles perfectly (S2S3).
Modified by koczeka at 8:43 AM 11/24/2006
Old Nov 22, 2006 | 05:12 AM
D-Rob's Avatar
Default Re: Crome users: What is your target idle? (koczeka)
800 RPM, I believe.
To get mine to idle on Skunk2 Pro2+'s, I had to set by base timing to 22* and adjust the throttle plate open a hair.
Old Nov 22, 2006 | 08:41 AM
98vtec's Avatar
moderator emeritus
Default Re: Crome users: What is your target idle? (D-Rob)
750
idle is screwy right now due to a really messed up TPS sensor
before it went bad, idled perfectly.
Old Nov 23, 2006 | 09:20 PM
Black R's Avatar
25 Year Member
800 plus or minus 50, just like stock.....
but since not connecting my iacv to my vacuum log, it's at 1200-1500 for some reason... (itb's)
Old Nov 24, 2006 | 09:59 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (Black R)
900 ish but as todd says make sure to go to advanced tables and make adjustments there as well and for skunk pro series cams i set bae ignition timing at idle around 22 deg
skags
May 26, 2014 01:08 PM
krazy one
32
Sep 6, 2010 09:10 PM
94typeR
Mar 28, 2007 05:49 AM
mark_is_gay
Oct 5, 2005 07:02 PM
matix
Sep 6, 2005 09:10 AM
