HELP!! passenger window wont go up!?!
Old May 8, 2002 | 08:28 PM
smokin rubber's Avatar
Default HELP!! passenger window wont go up!?!
any body know whats up with the passenger window in my accord? its power, and has worked fine up until now. I have the inner panel off and can't pull or push the window up manually, also there is no noise or movement from the passenger window when I press the drivers or passenger window up control. the drivers side still works normally. Da^^it, I checked all the connections on the passenger door, will check fuses in the morning,
Old May 8, 2002 | 08:39 PM
John's Avatar
New User
Default Re: HELP!! passenger window wont go up!?! (smokin rubber)
I'm sorry to say, but you may be screwed. The front PW motor is pretty weak in Accords, and yours needs to be replace ASAP. Do you hear the other motor working at all? Check the fuse under the dash, and then the C254 under the hood (when facing the front of the car, it's the 2nd row of fuses from the left). I can't remember if the PW motors run in parallel or series, but I will acknowledge that the Accord's PW motors are less than reliable.
Old May 8, 2002 | 08:45 PM
Default Re: HELP!! passenger window wont go up!?! (DunReit)
CRAP
Iwill check the fuse, the driver side works fine, but the passenger side is nada, nothing, no noise, no movement,
Old May 8, 2002 | 08:57 PM
John's Avatar
New User
I can tell that both of my PW motors have begun to see the tests of time... it happens unfortunately, I just hope you have a garage to hide your Accord when it rains...
Old May 8, 2002 | 09:21 PM
do you know how to replace the window motor, I couldnt figure out how the inner metal panel comes off the door. Does the whole door have to be replaced?
Old May 8, 2002 | 09:23 PM
John's Avatar
New User
No, probably just the motor or the PW motor relay. Does the right side PW work?
Old May 9, 2002 | 06:48 AM
update!!!
omfg, I am retarded!!!
you guys know that little window lock switch, to keep little kids and your drunk friends from playing with the windows, well I guess I forgot about that
but at least the windows work now and I still have a little $$$, just dont tell my car.
Old May 9, 2002 | 06:50 AM
CmptchAV6's Avatar
update!!!
dont worry we all do that every once in a while just most of us dont admit to it
Old May 9, 2002 | 06:52 AM
Gennady's Avatar
New User
Default Re: HELP!! passenger window wont go up!?! (CmptchAV6)
OMFG!! No we dont. Smokin Rubber is just stupid.
Old May 9, 2002 | 06:56 AM
Boughetto's Avatar
New User
update!!!
LOL, something I would do
Old May 9, 2002 | 07:57 AM
The_In_Kid's Avatar
update!!!
bahahahahahahahahahahaahhahahahahaahhahahahahaha
thats funny dumb stuff... oh well some people forget about it
Old May 9, 2002 | 08:00 AM
Raisn_Hell's Avatar
I guess you need to lay off the pot
Elmor001
15
Jan 23, 2017 02:38 AM
slipstreamvash
Feb 1, 2015 05:26 AM
ekkscott
Honda Civic (2001 - 2005)
Feb 5, 2012 09:27 AM
TRYLSTEG808
Mar 3, 2008 05:55 PM
