ITR pistons in b18c1
Old Nov 21, 2006 | 07:12 PM
jikespingleton's Avatar
Default ITR pistons in b18c1
can i buy the itr piston sna d just throw them into my b18c1 or is there more to. basically im askin if its just a direct swap between piston or do i have to get ITR connecting rods and pins.
Old Nov 21, 2006 | 07:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ITR pistons in b18c1 (jikespingleton)
It's a direct fit. Your compression ratio will be higher.
http://www.c-speedracing.com/h...c.php
Old Nov 22, 2006 | 10:00 AM
VTECth1s's Avatar
The compression will be much higher then stock, i would suggest tuning it as well right after installation, but you will need to hone the block first before putting in the ITR pistons, reason being, is that honing will allow correct fitment/seating in the cylinder for the pistons. Honing pretty much eliminates any irregularities or build up in the cylinder walls, which in fact benefits a lot as well as having correct fitment of the new pistons going in. And the rest you can use same parts, connecting rods, bolts..etc. and you'll be set. GL!
Old Nov 22, 2006 | 11:47 AM
Default Re: ITR pistons in b18c1 (DC2vtak)
cool. thanks guys.
dunked dc
Dec 6, 2010 04:45 PM
scooterbuilteh2
10
Jan 15, 2010 11:13 AM
B16beatdown
Mar 17, 2004 11:15 AM
rainmanEK
Jul 17, 2002 09:10 PM
SteelCityKid
Jan 10, 2002 12:08 PM
