sigh* worn crankshaft
so ive been having an engine knock for 2 weeks now, cuz the oil in my engine had leaked out and the car had no oil in it and i couldnt hear the knocking cuz my music was too loud, when i heard the knock.. it was too late, engine = toast.
so i posted the problem here before and some said i spun bearings
but anyways i changed all the piston rings, main bearings, rod bearings, pretty much everything that was fuked except for crankshaft.
my crankshaft =fuked and makes knocking sound.
this just came to my mind.. would the knocking sound eventualy go away ??
Damn, you already tore the engine apart and replaced everything?
What exactly did you find when you pulled the engine apart? Metal shavings? Be descriptive when you reply.
I am not sure I understand. Why would the knocking sound go away after time?
Based on this post: https://honda-tech.com/zerothread?id=1809296 I would say the engine is toast. My guess was a problem with the crankshaft.
Honestly, to save time and money, look into a new engine. Either do an H22 swap or maybe use your H23 head and build a G23 hybrid.
CodeBlue
Honda Civic (2006 - 2015)
11
Feb 3, 2010 09:25 PM
dacrxkid4rm253
Nov 29, 2007 12:07 PM
