ReInstalling cams, do i need liquid gasket for cam caps?
Old Nov 21, 2006 | 05:57 PM
drumminforev's Avatar
Default ReInstalling cams, do i need liquid gasket for cam caps?
The manual calls for using liquid gasket on the cam caps that dont stretch across both cams...is this neccessary, and if so whats the best kind
I saw something like atv liquid silicone gasket at autozone...will this work.
Like it says there, on the cam caps that hold the cams down
And could i use engine oil or is assmeble lube needed
Old Nov 21, 2006 | 05:59 PM
cranny's Avatar
24.224.233.247
Default Re: ReInstalling cams, do i need liquid gasket for cam caps? (drumminforev)
im pretty sure the manual says oil but wouldnt hurt for you to look. use high temp gasket maker. like permatex red. 12mm bolts go 16 ft/lbs , 10mm bolts go 8 ft/lbs.
Old Nov 21, 2006 | 06:06 PM
Default Re: ReInstalling cams, do i need liquid gasket for cam caps? (cranny)
its for a b16a2 so its 20ft lbs 12mm and 7ft lbs 10 mm, so others dont get confused
But thanks
Old Nov 21, 2006 | 11:50 PM
do i really gotta wait 24 hour to drive with this permatex like it says or will i be ok if i let it cure overnight
Old Nov 22, 2006 | 07:15 PM
HONDACURA-DB8's Avatar
Just go buy some HondaBond
Old Nov 22, 2006 | 07:21 PM
ok, well considering at the time i posted that i had fully assembled my valve train, so i doubt it. anyway im fine i just drove it and its fine.
Old Nov 22, 2006 | 07:23 PM
IntegraLova's Avatar
I would consider all the steps in the manual to be "neccessary".If the manual says to add liquid gasket, do it.Failure to follow intstructions could have bad concequenses.
Old Nov 22, 2006 | 07:38 PM
Default Re: ReInstalling cams, do i need liquid gasket for cam caps? (IntegraLova)
yes i figured that, which is why i was just saying i added it, let it sit over night and drove it arund now wit no probs
raverx3m
14
Aug 31, 2013 05:53 PM
DelsolVted
13
Jan 11, 2012 03:29 PM
mehrshadvr4
Apr 12, 2010 11:46 AM
drumminforev
17
Nov 29, 2006 05:40 PM
.RJ
May 10, 2003 09:19 AM
