RPM at Highway speeds
Old Nov 21, 2006 | 05:09 PM
jimeb's Avatar
Default RPM at Highway speeds
What is the normal RPM's at 60MPH for a stock 95 Del Sol VTEC?
Old Nov 21, 2006 | 05:27 PM
Nameless Warrior's Avatar
Default Re: RPM at Highway speeds (jimeb)
Are you having MPH problem? Cuz I do too. When I am at 80MPH on the Highways with my B16A and a S4c Tranny I am only at 3.6K RPM. I am suppose to be at 4.4 according to a transmission guru (Bense).
Your Del Sol Vtec use the same S4c tranny as I do, because you also use the B16.
Old Nov 23, 2006 | 07:29 AM
smokerz212's Avatar
i got b16a2 and i believe b16 tranny also... when im on the highway im running 120 km/h .... maybe 75-80 m/h... my rpm is 3500... is it normal? coz b4 when my car was stock when i run on that speed my tach is on 3k.
Old Nov 23, 2006 | 07:33 AM
platinumx6's Avatar
search gear ratios or sumtin along those lines and you will see break downs of the gears, rpms at certain speeds and final drive....
seeeeaaarrccchhh
Old Nov 23, 2006 | 03:09 PM
travisallenn's Avatar
i first saw the thread and thought
"why would you want to go 600 mph in a civic?"
heres a site that will calculate speed when you enter gear ratio's, tire size, and max engine rpm
http://www.csgnetwork.com/speedcalc.html
enjoy! now all you gotta do is find the numbers
Old Nov 23, 2006 | 04:27 PM
97civicdx's Avatar
I know that GSR's will tach at 4k at 80 mph
99-00 SI will be at 44-45k at 80 mph
Old Nov 23, 2006 | 04:31 PM
platinum00's Avatar
Default Re: RPM at Highway speeds (97civicdx)
the size of your wheel/tire diameter affects his too.
platinum
Old Nov 23, 2006 | 06:21 PM
EG2Driver's Avatar
Default Re: RPM at Highway speeds (platinum00)
tires are 195/50/15, stock tranny stock engine.
70mph = 4000 rpm
Old Nov 23, 2006 | 06:29 PM
komat's Avatar
Default Re: RPM at Highway speeds (Nameless Warrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">Are you having MPH problem? Cuz I do too. When I am at 80MPH on the Highways with my B16A and a S4c Tranny I am only at 3.6K RPM. I am suppose to be at 4.4 according to a transmission guru (Bense).
Your Del Sol Vtec use the same S4c tranny as I do, because you also use the B16.</TD></TR></TABLE>
you sir, dont have a si tranny on yours. s4c are 4.4 FD. so at 80mph your rpm should be at 4300rpm. the tranny you using is an LS with a4.266FD
use this site to see your mph/rpm
http://www.fatboyraceworks.com/gears/
Old Nov 23, 2006 | 06:38 PM
jdmjaser's Avatar
Default Re: RPM at Highway speeds (komat)
at 80mph im about 4400rpm or so...
99 b16tranny
lsv motor..
Old Nov 23, 2006 | 09:35 PM
cranny's Avatar
24.224.233.247
Default Re: RPM at Highway speeds (jdmjaser)
3 different kinds of B16A trannys. S1 , Y1 , S4C.
Transmission Name - Engine - 1st , 2nd , 3rd , 4th , 5th , Reverse , Final Drive
S1 , J1 - JDM B16A(X-Si) - 3.230 , 2.105 , 1.458 , 1.107 , 0.848 , 3.000 , 4.400
Y1 , Y1 w/LSD - JDM B16A(SiR) - 3.166 , 2.052 , 1.416 , 1.103 , 0.870 , 3.000 , 4.266
S4C , Y21 - USDM B16A2,B16A3 - JDM SiR2 - JDM SiR2 w/LSD - 3.230 , 2.105 , 1.458 , 1.107 , 0.848 , 3.000 , 4.400
Old Nov 24, 2006 | 12:28 AM
civic2slo's Avatar
b16 (del sol y21) 4400 rpms @ 80 mph
GSR 4150 rpms @ 80 mph
LS 3750 rpms @ 80 mph
These are going by speedo and tach in which some case might be alittle off.
XhaloZ
11
Jan 14, 2006 04:50 PM
Sliced Beard
Sep 15, 2004 06:39 AM
pkprelude
May 8, 2003 07:58 PM
pkprelude
May 8, 2003 04:48 PM
SeaBass
39
Apr 26, 2003 06:35 PM
