how to remove stereo ?
Old Nov 21, 2006 | 05:09 PM
yomayo's Avatar
Default how to remove stereo ?
hi guys,
how to remove stereo from honda accord 1998 lx sedan ?
I am looking for screws around it, but all i found were 2 screws on the bottom of the whole panel, removing them does not help anything
Old Nov 21, 2006 | 05:26 PM
Jonzey94's Avatar
Default Re: how to remove stereo ? (yomayo)
I have a 95 accord, try removing your ash tray should just pull out and give you access to the bottom of the radio....
Old Nov 21, 2006 | 05:31 PM
02 accord's Avatar
Pull out the clock, one screw behind it. 2 screws on the bottom side (that you already found). Once those are out, keep pulling on it until all the clips release. Mine was stuck when I first tried to remove it, but keeping goin at it, and it will come out.
yomayo's Avatar
Default Re: how to remove stereo ? (Jonzey94)
i was trying to remove this ashtray below stereo, but it does not move, dont wanna try to hard and brake it
Old Nov 21, 2006 | 05:32 PM
Jonzey94's Avatar
hey try to pull the ash tray out to give you access to the bottom of the radio....
Old Nov 21, 2006 | 05:33 PM
yomayo's Avatar
thanks for fast advice,
how to remove the clock ? just keep on pulling it out ?
Jonzey94's Avatar
im an idiot i reposted the same idea sorry.. did you look in the ash tray for screws...
Old Nov 21, 2006 | 05:34 PM
Jonzey94's Avatar
the clock face should just pull of and unplug... it should not be attached to anything....
Old Nov 21, 2006 | 06:26 PM
SteveoBA8's Avatar
Use a small flathead or something small/flat plastic tool to unclip the clock and the trim piece.
Old Nov 21, 2006 | 08:02 PM
concept11253's Avatar
Default Re: how to remove stereo ? (SteveoBA8)
I heard that a credit card works also to get it out. I personally used a small flat head screw driver.
Old Nov 21, 2006 | 08:18 PM
raceACCORDingly's Avatar
http://www.installdr.com/Insta....html
its supposed to be 94-97 and 98-02... use the one that says 99-00
Old Nov 21, 2006 | 10:03 PM
Heat's Avatar
Default Re: (raceACCORDingly)
Here's the instructions, from Honda, for installing the trunk mounted CD changer. Steps 24 through 28 walk you through removing the radio.
http://www.handa-accessories.c...k.pdf
I have the same radio in my car ('99 LX) with a trunk mounted Alpine CD changer hooked up to it. One of the things I like about this radio is that no security code is needed.
Old Nov 21, 2006 | 11:16 PM
sma_V6's Avatar
haha you have one of those lil kit things that turn your radio into a CD player.. using the tape deck lol.. i used to have that.. before after market head units... wow the good ole days
Old Nov 22, 2006 | 05:11 PM
yomayo's Avatar
guys, thanks for advice to all of you.
i will try to change my stereo soon and i will let u know how it is going
dheeruyadav
Jun 11, 2009 07:05 AM
88ernie88
13
Apr 5, 2009 12:31 AM
giff74
Mar 19, 2005 02:09 AM
