Rear strut bar trouble: HELP NEEDED!
Old Nov 21, 2006 | 12:10 PM
JDM_WHR's Avatar
Default Rear strut bar trouble: HELP NEEDED!
So, I bought a generic front strut bar off ebay, it said "97-00 prelude front strut bar" but, the mounting plate is a circle w/ only 2 holes. So I'm thinking that it's a rear strut bar, so I tried to test fit it and it was extremely hard to get it to line up, I think I'm going to need to drill a new hole in the plate.
Anyways I was wondering if people have had the same type of trouble before, if so how you fixed it. Any help/pictures would be great.
Old Nov 21, 2006 | 12:15 PM
GraphiteMW's Avatar
One word,
EBAY.
Old Nov 21, 2006 | 01:21 PM
petern101's Avatar
Default Re: (GraphiteMW)
some cheaper ones actually only use two holes on the front.
Old Nov 21, 2006 | 03:17 PM
JDM_WHR's Avatar
i tried to get it to fit in front no luck, the holes do not line up at all, even tried turning backwards, etc.
Old Nov 21, 2006 | 03:23 PM
avallach's Avatar
Default Re: (JDM_WHR)
If it's circular bracket, then it's for the rear. My experience is that the bracket does not sit flush, so even re-drilling it will not make it an optimal fit. Return it or throw it away. Usually not worth the effort/cost to return it. Leave the seller a negative review. Besides, those things are worthless.
Old Nov 21, 2006 | 04:20 PM
InvaderTrax's Avatar
If it doesn't fit the rear, then maybe it really is for the front. Pics?
Old Nov 21, 2006 | 06:54 PM
ethereal2pt2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">One word,
EBAY.</TD></TR></TABLE>
x2
in life, you get what you pay for.
Old Nov 21, 2006 | 08:20 PM
mgags7's Avatar
rear strut tower bars....waste of $$
spend elsewhere, perform better
Old Nov 21, 2006 | 08:26 PM
prelude1897's Avatar
Default Re: (bb4ever)
I bought a rear lower tie bar off ebay, and I have to shave it a bit just to make it fit. I'm just a little lazy right now to do it, but I'll eventually get around to it. I just bought it for looks anyways
Old Nov 21, 2006 | 09:30 PM
v1nyd's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (JDM_WHR)
I got one just like that it fits fine and works great for a ebay strut bar yeah it only comes with two holes...its all u need and u have to unscrew the bracket that holds the wires up and move them slightly to get the strut bar to line up correctly
Old Nov 21, 2006 | 10:49 PM
Default Re: Rear strut bar trouble: HELP NEEDED! (JtIcE2Hot)
did you get one of those $12 ebay ones. maybe i should get one just for looks.
Old Nov 22, 2006 | 05:11 AM
integra15's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (_BB6)
Those cheap ones on ebay don't fit.
Old Nov 22, 2006 | 07:50 PM
Default Re: Rear strut bar trouble: HELP NEEDED! (integra15)
Not true. Mine fit perfectly and was $22 shipped
Old Nov 22, 2006 | 08:20 PM
plikit's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (InvaderTrax)
i bought the front, rear, and lower for the bling... PLUS the rear strut bar functions as an amp mounting location. i got a couple pipe brackets and it just hangs from it. ill get some pics soon.
Old Dec 8, 2006 | 11:22 PM
dafuzzbudd's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (plikit)
im thinkig about going cheap at the moment.
are front + rear uppers better than nothing?
Old Dec 8, 2006 | 11:26 PM
vinuneuro's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (dafuzzbudd)
No. You lose _ amount of $.
Old Dec 9, 2006 | 12:39 AM
dafuzzbudd's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (vinuneuro)
what about solid 1 piece types? (more expensive)
Old Dec 9, 2006 | 07:55 AM
TylerC161's Avatar
i bought a front and rear.. the front fit perfect, the rear didnt fit at all
Old Dec 9, 2006 | 09:31 PM
Prudz_lude's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (TylerC161)
i dont get why everyone says they do nothing. Yah im sure they dont if you only have one strut bar. Odds are all the people saying this dont have them. They make your chasis more rigid. there is a noticeable difference in my suspension with the strut bars. My car is lowered with neuspeed and kybs adjustable and after that i bought the front upper, rear upper, and lower tie bar and with all of those combined there was a noticeable difference in the handling. they have to be properly torqued as well to be working properly. I dont disagree one bar will do nothing but try buying all of them and im sure you will notice a difference to
Old Dec 10, 2006 | 05:41 AM
integra15's Avatar
Default Re: Rear strut bar trouble: HELP NEEDED! (Prudz_lude)
is it a Megan? I bought one of those and it sucked, didn't fit at all so I sent it back
Davidss
Jul 23, 2009 12:59 PM
BlownH23a
Feb 20, 2007 04:04 PM
crxcrazysi
Feb 27, 2005 03:23 PM
cityofcaterpillars
Welding / Fabrication
Aug 26, 2004 03:35 AM
fubar
Oct 9, 2002 08:55 AM
