compression numbers on 12:1 LS vtec
Old Nov 21, 2006 | 08:03 AM
SpoolnByYou's Avatar
Default compression numbers on 12:1 LS vtec
whats up guys,
i was wondering if anyone knew the compression numbers (when you do a compression test) on a LS-vtec with a b16 head and 12:1 comp. pistons. i bought a "built" LS vtec with arias 12:1 comp. pistons,did a compression test last night and all 4 cylinders are at 210psi. this sounds low to me for 12:1 comp. pistons.?
Old Nov 21, 2006 | 09:54 AM
Default Re: compression numbers on 12:1 LS vtec (SpoolnByYou)
does 210 sound right?
Old Nov 21, 2006 | 10:27 AM
Sam92Teg's Avatar
From what I have heard, different gauges and methods for performing the test will yeild slightly different numbers. The important issue, is that they are consistent with minimal variance and not drastically low. Your engine should be good to go.
Also, if the rings are new with few miles, they could still be in the seating process. Check again after 50 miles or so.
Old Nov 21, 2006 | 03:10 PM
allm0torGSR's Avatar
Default Re: compression numbers on 12:1 LS vtec (Sam92Teg)
My B18C1 is 12:1 compression, my #'s are 260 270 265 255.
210 sounds low to me, but if the build is new like sam said, then it's not a big worry. As long as all 4 cylinders are in the same area.
SupaFly_Honda
Feb 10, 2005 11:46 AM
dwn4cause
Dec 22, 2004 07:58 AM
underpressure02
Sep 8, 2003 08:20 AM
K20 EG
Jun 17, 2003 11:26 AM
TeStUdO
May 5, 2003 05:28 PM
