rear wheel bearing replacement??
I know I have to replace it! Now my question is how hard is the process! Is it a pressed bearing meaning I will have to have it pulled and then pressed? Anything will help just let me know if any one has any hints, suggestion, helpful advice anything!
Thanks
Thanks
Anyone know anything about how easy/hard this gonna be it was midnight when we took the wheel off and couldn't really see much so I'm gonna get into it more after work.... suggestions anyone???
You buy the bearing/hub as an assembly--it has the wheel studs attached to it. Loosen the rear spindle nut and it should pull right off. Sometimes--the inner bearing race corrodes to the spindle and makes it a bitch to pull off.
PaChiLa Leader
Feb 18, 2009 05:21 PM
