Need Help Bad (Searched and Searched) Solid CEL and Bogging Issues
Old Nov 21, 2006 | 06:43 AM
IMPORTMyth01's Avatar
Default Need Help Bad (Searched and Searched) Solid CEL and Bogging Issues
First off I have tried the usual....FPR, Fuel Filter, Distributor Cap, Rotor Button, Swapped ECU to a good one, New Wires, Plugs, Map Sensor...etc.
Here's the deal...car cranks runs fine idles like a champ.....while driving if I were to take a corner downshift and slowly accelerate at around 2500 RPMS the car feels as if it hits a brick wall and detonates, if I leave the trottle at the same position it will continue to do this and bust up and bog out. Now If I full throttle it at any point and even when initially taking the turn it will never occur and car will run like a champ.
Anyone have this same problem?
FYI Timing is set to stock and there are no mods, this is my daily driver and it seems to give me a lot more problems then my race cars.
Thanks In Advance
Old Nov 21, 2006 | 09:53 AM
Mr. Giggles's Avatar
Default Re: Need Help Bad (Searched and Searched) Solid CEL and Bogging Issues (IMPORTMyth01)
I had the same problem, and it turned out that a wire on my map sensor was disconnected..Got it soldered and there was no issue after that..But you already checked that..so i am no help
Old Nov 21, 2006 | 12:32 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Need Help Bad (SmrCRX)
Car? Engine?
Old Nov 22, 2006 | 07:50 AM
hmm...ill check the connectivity, thanks for the input..
90 Civic Hatch Stock D15b2 Dual Point
Old Nov 22, 2006 | 08:21 AM
colnago's Avatar
If the car has a EGR valve, it could be clogged. you might want to look into that if you have one. If you don't have one, nothing gained or lost. also what is the check engine code that is flashing on the ECU, get back to me with the nuber of blinks, I have book can tell you what the code means.
Good luck
Colnago
Old Nov 22, 2006 | 03:11 PM
its a solid cel...usually mean bad ecu but in this case I swapped ecus from a running car with no problems....still working on it
Old Nov 22, 2006 | 04:42 PM
colnago's Avatar
Default Re: (IMPORTMyth01)
You mean the red blinking light inside the ECU is always on. it shouldn't be. look at bulb inside ecu turn ignition to the on position. Light should flash once then go out with no trouble codes. If you have trouble codes stored they will flash after the one flash that signals ecu is functioning properly. there would be no one blink if the ecu was bad.
Old Nov 22, 2006 | 05:39 PM
schardbody's Avatar
main relay FTW...... resolder the joints and try again.
Old Nov 22, 2006 | 05:46 PM
ryanplayjoint's Avatar
Default Re: (schardbody)
Yeah, the CEL code would be a great starting point.
Old Nov 22, 2006 | 05:47 PM
Default Re: (ryanplayjoint)
I think if the car is a manual it doesn't have a EGR valve.
Old Nov 22, 2006 | 07:06 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanplayjoint &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the CEL code would be a great starting point. </TD></TR></TABLE>
you people dont realize what a SOLID cel means????
NO BLINKY BLINKY, SOLID CEL, TURN KEY TO ON, CEL NEVER GOES OUT, NO POWER TO ECU, NO GROUND AT ECU, ETC.....
Old Nov 23, 2006 | 09:30 AM
oh o.k I thought you meant CEL in the dash, did you check power and ground to the ecu, and check out the power, signal, ground of the TP sensor. If your not sure on how to I'll let you know.
Get back to us on that.
Old Nov 27, 2006 | 05:44 AM
Sorry been out of town...will be chaingin main relay and trying a 3rd ecu today....All grounds and 12v power continous throughout the wiring harness to the ecu.
I will check the TPS also.
Thanks for all of your input
bertooo
Nov 7, 2011 11:28 PM
Boosted_90Teg
Dec 6, 2010 07:17 AM
goula SOS
Jul 20, 2003 08:14 PM
