In Cabin Air Filters
Old Nov 21, 2006 | 05:59 AM
I Am White's Avatar
Default In Cabin Air Filters
I know that you can take off the shield under the glove box, and remove a round fan and see two filters up in the dash. I assume that these two filters are to filter cabin air. Well mine are pretty dirty due to smoking, but I couldnt figure out how to get to them to change them.
How do I access those filters to change them?
Old Nov 21, 2006 | 09:02 AM
I Am White's Avatar
Default Re: In Cabin Air Filters (I Am White)
A help bump
Old Nov 21, 2006 | 09:35 AM
FullEP3's Avatar
I did this last year ... I will take a look at it tonight when I get home and answer you if no one has by then.
There are two clips that hold the glove box when you open it ... you have to unclip the glove box and it will swing down out of the way ... then you can access everything behind it. I think at that point you can see the first filter ... should be located in upper right corner behind glove box ... it should just slide out towards you. The next filter is to the left of the first ... I think it slides over to the right and then out towards you.
Give this a try ... like I said ... I will take a look at this when I get home from work today and have the car in front of me with the factory repair manual.
It is fairly straightforward once you get the glove box down ... good luck
Old Nov 21, 2006 | 12:06 PM
BarracksSi's Avatar
At least on an EP, those clips to drop the glovebox are pretty easy once you figure them out. Each one is a rubber stopper, and beneath it (or "towards you") on the outside, you'll feel an indentation. Lift the glovebox a couple inches, push in on that indentation, and the clip will pop out and you can rotate it out of its hole.
You'll see the cover for the filters; pop it off and pull each one out. This is what my Honda dealership does before it charges a hundred bucks.
Old Nov 21, 2006 | 10:35 PM
thrty8street's Avatar
Default Re: In Cabin Air Filters (FullEP3)
i need to change mine on my car aswell. anyone know what the purpose of these filters are or if its even necessary?
Old Nov 22, 2006 | 02:40 AM
BarracksSi's Avatar
I'd just replace them -- they can be found for around ten bucks each online.
Their purpose is... well, to filter the cabin air. Just like their name says.
Boopaa
May 18, 2018 04:57 AM
conejo77
Honda CR-V & Element
Oct 12, 2014 12:28 PM
dpine
Sep 9, 2008 08:29 AM
daboohk
Honda Civic (2001 - 2005)
Mar 10, 2008 10:10 AM
keebler65
14
Feb 22, 2003 05:01 PM
