Car in safety mode?
Old Nov 21, 2006 | 05:48 AM
ZenDynasty's Avatar
Default Car in safety mode?
What up guys just need some more help tried doing some searching couldn't find my answer. I just swapped my b18C1 into my EJ1, I have no check engine lights but my car can't go past 65 and the rev limiter is on and I belive I can't go past 4-6k rpm's?
I know it's not my Vtec wiring b/c I had a CEL before and switched the Vtec wiring around and that solved my issue. Could it be knock sensor will it cause my issue?
Any help would be great it's my day off and trying to get as much done as possible.
Thanks,
Old Nov 21, 2006 | 07:28 AM
Dilly's Avatar
Default Re: Car in safety mode? (ZenDynasty)
you did get a gsr ECU right?
Old Nov 21, 2006 | 07:39 AM
spoonracer84eg's Avatar
Sounds like you dont have the right ECU for the motor because if you did and didnt have your knock sensor wired up you would be throwing an ECU code for it. Also the knock sensor would not cause the problems you are having. I drove my car for months without one. You got other issues
Old Nov 21, 2006 | 09:26 AM
ZenDynasty's Avatar
I have a GSR ecu in there,
Old Nov 23, 2006 | 07:29 AM
ZenDynasty's Avatar
Bump for some Turkey Day Help.....
Old Nov 24, 2006 | 01:43 PM
ZenDynasty's Avatar
bump any other ideas? Just put tach in and I can't go past 3500 rpm and no CEL.
huckaboo
Dec 4, 2009 10:34 AM
honda addictions
Sep 28, 2009 06:24 AM
all_motorsi
May 6, 2007 08:55 PM
Kangolbrand
Aug 13, 2006 05:55 PM
shatchi
17
Feb 1, 2005 10:00 AM
