which rods to use?
Old Nov 21, 2006 | 02:38 AM
xQB21x's Avatar
Default which rods to use?
on my b20vtec setup? what can you tell about eagle rods, would you recommend them, or would you recommend something else? is the weight reallly matters?
Old Nov 21, 2006 | 03:26 AM
EITCP's Avatar
Default Re: which rods to use? (xQB21x)
if you will rev it lower than 9000 rpm then eagle is ok, otherwise i would rather suggest you Crower ultralight rods.
Old Nov 21, 2006 | 09:20 AM
Natural Aspirations's Avatar
Carrillo
Old Nov 21, 2006 | 12:54 PM
alterdcreations's Avatar
probe ultralight rods
Old Nov 21, 2006 | 01:10 PM
DonF's Avatar
Default Re: which rods to use? (alterdcreations)
[QUOTE=alterdcreations]probe ultralight rods
If you need a new set of GSR, "R" probe ultalites I have them for $200.00
Old Nov 21, 2006 | 01:11 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
eagle has alot of quality of metal issues, seeing as how its a china rod. I'd say spend the money, get a set of Carillos.
Old Nov 22, 2006 | 10:56 AM
xQB21x's Avatar
Default Re: which rods to use? (ComeOnKip)
hm... i checked the weights
eagles are approx 510 grams
probes are 489 gr
manleys are 487 gr
and corrillos are the lightes with 421 gr but the are pro-a not h-shaped
guys may be i have to save some money are get myself titanium rods? ))))
Old Nov 22, 2006 | 10:58 AM
97L-esVeeTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xQB21x &raquo;</TD></TR><TR><TD CLASS="quote">hm... i checked the weights
probes are 489 gr
manleys are 487 gr
guys may be i have to save some money are get myself titanium rods? ))))</TD></TR></TABLE>
What application?
Old Nov 22, 2006 | 01:28 PM
Why are you looking for an H-shaped rod?
Old Nov 23, 2006 | 12:47 PM
xQB21x's Avatar
Default Re: which rods to use? (Natural Aspirations)
I'm not looking for h-shaped rods, but all the others except for corillos are h-shaped. can you explain me why i don't need h-shaped rods?
applications is going to look something like this: b20 block, b18 gsr head, b20 crank, wiseco 12:1 pistons, 50mm ITBs, toda header, haven't thought about head yet.
Old Nov 23, 2006 | 01:25 PM
IT'S ME DAVID's Avatar
NooB
eagle rods with the big arp rod bolts
Old Nov 23, 2006 | 02:35 PM
Fat Chick Magnet's Avatar
Default Re: which rods to use? (IT'S ME DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods with the big arp rod bolts </TD></TR></TABLE>
Old Nov 24, 2006 | 02:10 PM
xQB21x's Avatar
Default Re: which rods to use? (dc2rtek)
apr bolts - yes but eagle rods - i'm not sure
Old Nov 24, 2006 | 03:30 PM
if its a n/a build then get the lightest rods posible
Old Nov 24, 2006 | 03:40 PM
ExospeedAMcrx's Avatar
We use the Carrillo Pro-A and SA for All motor applications. They are the lightest and obviously Carrillo has a great reputation as a rod company.
Old Nov 26, 2006 | 02:48 AM
xQB21x's Avatar
Default Re: which rods to use? (exospeedAMcrx)
can you give me the exact catalogue number of carillo rods you use for your b20vtec setups with stock b20 crank? cause I'm a little bit confused.
Old Nov 26, 2006 | 04:14 AM
b20 crank and rods = ls crank and rods
RACEPAK
Sep 14, 2010 03:00 PM
Da K00l Aid Mayun
May 26, 2005 04:43 PM
austrian type-R
Nov 3, 2004 06:42 AM
1BADGS-R
Dec 30, 2003 07:08 PM
