Civic EK proper offset 15x6.5 (TE37)
hello,what would be the correct offset for an EK9 with TE37 +39 or +45 ?
(stock is +50)
if you have any pictures with 15x6.5 please post them.
(stock is +50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear »</TD></TR><TR><TD CLASS="quote">
if you have any pictures with 15x6.5 please post them.</TD></TR></TABLE>
te37 pics
te37 pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear »</TD></TR><TR><TD CLASS="quote">hello,what would be the correct offset for an EK9 with TE37 +39 or +45 ?
(stock is +50)</TD></TR></TABLE>
Either one should work fine, actually.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear »</TD></TR><TR><TD CLASS="quote">thank you , i care lot about how its going to look,i dont want to go much outside of the fenders.</TD></TR></TABLE>
Go with the +45 wheels then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear »</TD></TR><TR><TD CLASS="quote">another question do you know if the white color of TE37 is NH0 ? (championship white)</TD></TR></TABLE>
No, it's not.
No, it's not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No_Fear »</TD></TR><TR><TD CLASS="quote">i c,if you have any pics with te37 EKs 39 or +45 pls post.</TD></TR></TABLE>
Picture threads belong in the Appearance/Cosmetic forum. You could try searching or posting there.
Additionally, most pictures on this site will be of USDM cars (keep in mind that the US never received the EK9 model) or otherwise non-EK9 models (such as EJ6, EJ7, EJ8, EK3, EK4, EM1, etc.). The Type-R wheel track was 10mm wider than other '96-00 Civic models, so it effectively would set the wheels 5mm farther outboard at each corner than the non-EK9 '96-00 Civics (unless they were converted to 5-lug hubs), which has the same effect as using wheels with a 5mm lower offset.
RhdRicheeee
Mar 8, 2005 01:12 AM
