91 ACCORD rear disc breaks
Old May 8, 2002 | 06:25 PM
RUBZERK's Avatar
Default 91 ACCORD rear disc breaks
I Have A 91 ACCORD & I wanna put DISC BREAKS on the rear, But I dont know if I can use 92 or 93 REAR.
has anybody done this, or know of anybody that has, IF SO PLEASE HELP ME.
i need to know which model to get them from & how hard its gonna be.
THANKS
Old May 8, 2002 | 06:28 PM
Gennady's Avatar
New User
Default Re: 91 ACCORD rear disc breaks (RUBZERK)
92 and 93 rear disks are exactly the same.
Old May 8, 2002 | 06:37 PM
RUBZERK's Avatar
Default Re: 91 ACCORD rear disc breaks (Wont be beat)
but i need to know if they will fit a 91 accord
Old May 8, 2002 | 06:38 PM
Gennady's Avatar
New User
All rear disk breaks from 90-93 were the same.
Old May 8, 2002 | 06:39 PM
RUBZERK's Avatar
how sure r u ?
Old May 8, 2002 | 06:42 PM
Gennady's Avatar
New User
Call up a Autozone, and ask for 90 rear disk part number and 93 rear disk part number, they should match up.
Old May 8, 2002 | 06:44 PM
RUBZERK's Avatar
kool ill do that THANKS
Old May 8, 2002 | 06:47 PM
SOHCArchangel's Avatar
or just go on majestic....
http://www.hondaautomotiveparts.com
and research
Old May 8, 2002 | 08:52 PM
thenick's Avatar
this would be true, IF they made rear discs for 90-91
90-91 EX/SE did NOT have rear discs, only 92-93. HAPrecycling.com has the brake changeovers, but i would do it through a junkyard and buy "performance" rotors and pads...should cost around $160 without the "performance" stuff....
ill give you a list of what you need when i get home
Old May 9, 2002 | 05:23 AM
4doorH22's Avatar
Old May 9, 2002 | 05:48 AM
muskrat's Avatar
Default Re: 91 ACCORD rear disc breaks (4doorH22)
Follow along and try to imagine this... I have a '91 Accord with rear drums, I go to a junkyard and find an untouched '92 or '93 Accord with the rear discs.
What parts do I need to remove off of this car to make my car have rear discs?
Any parts that I will need to fabricate/buy?
TIA
Justin D. Fender
Old May 9, 2002 | 05:56 AM
Gennady's Avatar
New User
Default Re: 91 ACCORD rear disc breaks (ixiblindixi)
What I meant to say was the rear disks will fit all Accords from 90-93. Sorry if I confused you.
Old May 9, 2002 | 06:00 AM
4doorH22's Avatar
Default Re: 91 ACCORD rear disc breaks (muskrat)
I would guess the trailing arm and control arms are the same, so you'd need the entire rear knuckle with the hub and caliper attached and some lines. The '90-'91 and '92-'93 rear knuckles look identical, but have different part numbers, so I dunno.
Contact http://www.hasport.com and they should be able to tell you exactly what you need.
Old May 9, 2002 | 06:49 AM
2point6's Avatar
I have done the swap myself and alll of 4doorHhh's post is correct. I just want to add that you need the cables for the emergency brakes as well (from the disk set up)
Old May 9, 2002 | 06:50 AM
Gennady's Avatar
New User
Default Re: 91 ACCORD rear disc breaks (2point6)
Is that a new Honda engine? Hhh? Is it Veetechk?
Old May 9, 2002 | 06:52 AM
2point6's Avatar
LOL! Just woke up! I meant 4doorH22's post. I'm going back to bed now...
[Modified by 2point6, 3:54 PM 5/9/2002]
Old May 9, 2002 | 06:33 PM
RUBZERK's Avatar
where do i get exact info on how to do the conversion
Old May 11, 2002 | 12:30 AM
IwanAturBo's Avatar
ermm.. well.. one of u guys made an error.. they do make rear disk for 91 accords.. i have a 91 se and i have rear disk .. i dunno if they do it for the coupe but i know for sure they do it for the 4 doors..90- 91 se and ex.. they have rear disk..i just wan to correct that.. hehehe.. hope that helps.. later
Old May 11, 2002 | 04:13 PM
Gennady's Avatar
New User
Default Re: 91 ACCORD rear disc breaks (IwanAturBo)
I wasnt aware that there was a 4th gen SE coupe.
Old May 12, 2002 | 06:11 PM
RUBZERK's Avatar
well i have a 91 lx i need to know if i can put them on it
Old May 15, 2002 | 01:14 AM
IwanAturBo's Avatar
i have 91 se 4 door.. not coupe.. but the coupe suspension should be the same with the 4 door.. nothing different at all.. it should just bolt right on.. but u need to get the whole joint and knuckle and everything from the junk car and just inter change them.. no prob at all.. later
Old May 15, 2002 | 05:18 AM
Gennady's Avatar
New User
Nevermind, I saw one yesterday.
Old May 15, 2002 | 06:47 PM
RUBZERK's Avatar
Default Re: 91 ACCORD rear disc breaks???????????????
Has anybody done this conversion ???????
Old May 15, 2002 | 06:53 PM
4doorH22's Avatar
Default Re: 91 ACCORD rear disc breaks??????????????? (RUBZERK)
Dude, read the posts again. 2point6 has done it. All necessary parts have been listed. What more do you need?
Old May 15, 2002 | 06:57 PM
RUBZERK's Avatar
Default Re: 91 ACCORD rear disc breaks??????????????? (4doorH22)
HOW ABOUT SOMEBODY TO DO IT 4 ME
