Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sway Bar Question for 2000 Civic Si Coupe
Old Nov 20, 2006 | 07:04 PM
doublezero_si's Avatar
Default Sway Bar Question for 2000 Civic Si Coupe
I searched, but I haven't found what I was looking for. Besides taking my front one out I was thinking about getting a new aftermarket sway bar for the rear of my 2000 Si. However I heard the sixth generation Civic has a weak subframe and I don't want to get an ASR kit because I want to stay in street-prepared and I think the ASR would kick me into SM. What sway bar is good out there?
Old Nov 20, 2006 | 07:38 PM
vietnameeh's Avatar
i believe they amde the suspension technique sway bar/tie bar combo legal in sp...
Old Nov 20, 2006 | 08:10 PM
suprmods's Avatar
comptech also has a bar i believe.
Run higher rear rates and barely any camber.
Old Nov 20, 2006 | 09:09 PM
vietnameeh's Avatar
i always thought the comptech piece was in the same boat as ASR with ruling but i could be wrong
Old Nov 20, 2006 | 09:22 PM
jtp05's Avatar
The Comptech piece and the ASR piece are both illegal in SP because they attach to the frame in multiple places.
Old Nov 21, 2006 | 07:17 AM
rmcdaniels's Avatar
Default Re: Sway Bar Question for 2000 Civic Si Coupe (doublezero_si)
Why not just get a Beaks subframe reinforcement kit? I used one on my '99 Si with a 24mm Mugen bar for road course and autocross, never had any problems with it. I don't know what it would to for classing, I was already in SM for other reasons, but it's just a couple of little metal mounting plates that distribute the load over a greater section of the subframe. Definitely do something if you go with a bigger bar though, the mounting area on my subframe was very flimsy.
Old Nov 21, 2006 | 07:35 AM
nonsense's Avatar
Default Re: Sway Bar Question for 2000 Civic Si Coupe (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Why not just get a Beaks subframe reinforcement kit? I used one on my '99 Si with a 24mm Mugen bar for road course and autocross, never had any problems with it. I don't know what it would to for classing, I was already in SM for other reasons, but it's just a couple of little metal mounting plates that distribute the load over a greater section of the subframe. Definitely do something if you go with a bigger bar though, the mounting area on my subframe was very flimsy.</TD></TR></TABLE>
The Beaks kit would be legal. I've seen a few subframe tearouts with it though. I have a Beaks kit now, but daily drive with the bar disconnected and only connect it for the track or AutoX as I'm afraid that the daily abuse would cause the subframe to eventually give in.
Old Nov 21, 2006 | 01:31 PM
Default Re: Sway Bar Question for 2000 Civic Si Coupe (nonsense)
A lot of feed back! Thanks everyone! All in all, a 6th gen Civic with a rear sway bar and concerning reinforcement/not breaking the subframe and staying out of SM is pretty hard to work with. Also, I'll research the Suspension Tech., and the Beaks.
Old Nov 21, 2006 | 08:28 PM
gabebauman's Avatar
I daily drove and autocrossed my 98 civic ex for a year with the beaks kit and 22mm ITR sway bar. Never had any problems. I've since upgraded to the ASR bar though.
JJ-Built
Suspension & Brakes
Nov 3, 2005 01:08 PM
gakkuken
21
May 23, 2003 02:29 PM
EleanoR
27
Jan 21, 2003 07:45 PM
96 SOHC VTEC
Jun 12, 2002 01:04 PM
