GSR mild build up need help
Old Nov 20, 2006 | 06:57 PM
tapboyzlilj's Avatar
Default GSR mild build up need help
Alright here is the deal i have a GSR with bolt on's right now, p28chipped blox im i/h/e in a 92 civic sedan currently running 14.5 @95mph with street tires, goal's are 13.6-13.9 on street tires. Setup well be...
Blox Type A cams
Type R outter valve springs with Portflow inner
Skunk cam gears
B16 PR3 pistons
B16 S4C TRANNY
What times do you think i'll be running after thanks... Or you could give me your ideals thanks
Old Nov 20, 2006 | 07:39 PM
95 integra's Avatar
Default Re: GSR mild build up need help (tapboyzlilj)
I'd step it up to a stage II cam....the stage I is less aggressive then you might think.
Old Nov 20, 2006 | 08:22 PM
jdmegmong's Avatar
I ran a 13.4(GSR, P30 pistons, portflow valvetrain, type r cams, itr program ecu, blox im, 65mm jg edelbrock TB, Greddy 4-2-1 header, GSR transmission) in a eg hatch weighing in at 2105 lbs on MT 20x6x14 slicks. Best street tire et was 13.8.
Old Nov 20, 2006 | 08:28 PM
Default Re: GSR mild build up need help (jdmegmong)
Dang thats what i want mid to high 13 i'll be happy, peeps tell me if i run slicks i'll be in the 13's but i dont want too, i want to do it on street tires... thanks
Old Nov 21, 2006 | 04:52 AM
reallycooleg's Avatar
street tires or drag radials??
Old Nov 21, 2006 | 09:05 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reallycooleg &raquo;</TD></TR><TR><TD CLASS="quote">street tires or drag radials??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tapboyzlilj &raquo;</TD></TR><TR><TD CLASS="quote">i want to do it on street tires... </TD></TR></TABLE>
I thought you had to be able to read in order to write.....
Old Nov 21, 2006 | 10:21 AM
Default Re: GSR mild build up need help (95 integra)
LoL yes i'm running 14in HX rims on some **** tire's called Hercules ever heard... does anyone have portflow inner springs for sale, juss need the intake side, thanks for stopping by...
Old Nov 21, 2006 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">
I thought you had to be able to read in order to write..... </TD></TR></TABLE>
well..drag radials are street tires...and then there are cheap *** grocery getter street tires...i was justg wonduring which ones he was running with....lots of people refer to their drag radials as street tires...smart ***!
Todallybuilt
Apr 11, 2018 08:01 AM
dblock
Oct 10, 2006 03:09 AM
Grip
May 9, 2004 04:01 PM
riceboyEFsi
Jul 22, 2003 10:27 PM
comptechgsr
Feb 18, 2002 04:05 PM
