Will hitting 13's be an easy task?
Old Oct 4, 2006 | 05:49 PM
dblock's Avatar
Default Will hitting 13's be an easy task?
whats up guys. i have a 92 cx hatch with a usdm 97 full gsr swap with i/h/e . i tracked the car on street tires and ran a best time of 14.5 @94 mph on regular street tires.
i just intstalled a skunk 2 pro series i/m , put on a o2 sensor (didn't have one before) , stage 2 clutch , and street tuned the car on a vafc2 .
im going to go back to the track as soon as i have another day off. should i be able to hit 13's? im going to run on bfg's drag radials (205's) btw.
thanks for any feedback will be much greatly appreciated
Old Oct 4, 2006 | 05:51 PM
Mugencrxsir1's Avatar
Default Re: Will hitting 13's be an easy task? (dblock)
It's good chance you will hit 13.9 or low with drag radials, but I would spend the money on slicks. That's just my opinion.
Old Oct 4, 2006 | 05:53 PM
JDM94EG28's Avatar
you should break a high 13 with a good 60'
Old Oct 4, 2006 | 05:54 PM
dblock's Avatar
i thought about it but i didnt think my setup would need slicks.
plus i got a great deal on the tires since my friend works at walmart so i basically paid less than half the price for them
Old Oct 4, 2006 | 05:56 PM
dblock's Avatar
Default Re: (dblock)
yea my 60 foot on the 14.5 run was 2.280 so i know i can do better
Old Oct 4, 2006 | 06:03 PM
dblock's Avatar
anyone else have any words of wisdom?
Old Oct 4, 2006 | 07:16 PM
dblock's Avatar
anybody?
Old Oct 4, 2006 | 07:29 PM
one slow coupe's Avatar
Should be possible. with the radials get a 2.0 60' and your there..
have you tried any weight reduction?
Old Oct 4, 2006 | 07:37 PM
dblock's Avatar
I took out the back seats , spare tire, and etc.
I still have all panels and carpet and what not.
Old Oct 4, 2006 | 08:31 PM
gsr x civic's Avatar
i don't think that taking out that stuff matters. . . because i believe it's every 100 lbs light is 1/10 of a second. . . or maybe it's 10 lbs? one or the other but i guess every little bit helps.
also, it usually depends on the launch too. if you have a good launch, you'll have a slightly better time. practice that if you want a better time.
you said you street tuned your car on a vafc. . .meaning you have one? what's your crossover point set at? what kind of ecu do you have?
Old Oct 8, 2006 | 05:10 PM
N20civicB18's Avatar
Default Re: (gsr x civic)
street tuning a vafc is usless, take it to the dyno.
BTW: 100lbs > 1/10 second
Old Oct 8, 2006 | 05:17 PM
wooh. i was correct.
anyway, you'd probably want to make sure you have an aftermarket ecu so that you can get that vafc tuned properly. right now, i'm rockin a p28 chipped ecu, but hondata would definitely be much better, and it's well worth the money.
Old Oct 8, 2006 | 06:16 PM
NathanMorris's Avatar
no.
I've never seen a GSR i/h/e hatch, in person, run 13s without a great deal of weight reduction or slicks..and even with slicks, it's gonna be a close call.
Nathan
Old Oct 8, 2006 | 08:03 PM
tha_badguy's Avatar
if ur car wasnt capable of hittin 13's b4
i dont think just an im will help without anything else done to the head
Old Oct 8, 2006 | 11:38 PM
BoostedJeff's Avatar
Default Re: (tha_badguy)
just go do it, and find out.
Old Oct 9, 2006 | 02:21 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dblock &raquo;</TD></TR><TR><TD CLASS="quote">stage 2 clutch</TD></TR></TABLE>
try some stage 5 weight reduction.
Old Oct 9, 2006 | 09:18 AM
H9Omega's Avatar
im not sure how different the sea level or track conditions are were you ran your car but my buddies 95 cx hatchback with a JDM B18c stock gsr with just and intake and greddy catback exhaust ran a 13.9 consecutively and this was on gsr stocks with cheap tires.
Old Oct 9, 2006 | 09:21 AM
Boner_Ben's Avatar
I went 13.7@101 in my stock gsr swapped hatch with i/h/e and tuning. I've also been in the 13's with mph ranging from 96-101 so you are almost there.
Old Oct 9, 2006 | 01:32 PM
fmfkid250's Avatar
back in the day i went 14.0 at 101 with no tuning and bliztak tires, on a stock gsr civic cx
(powershifting on a gsr trans)
its there no problem
Old Oct 9, 2006 | 08:02 PM
NathanielH's Avatar
Default Re: Will hitting 13's be an easy task? (NathanMorris)
your wrong
Old Oct 9, 2006 | 10:58 PM
gutted's Avatar
Default Re: Will hitting 13's be an easy task? (NathanielH)
should be possible my boy ran a 14.0 in his eg - jdm gsr swap, skunk2 IM, clutch and exhuast. i say get slicks. i ran 13.3 in my "bolt-on" ls/vtec
Old Oct 9, 2006 | 11:35 PM
Drag_Racer_DRU's Avatar
Default Re: Will hitting 13's be an easy task? (gutted)
very easy, I did it 6 years ago with a b16 in a EG all motor
Old Oct 10, 2006 | 01:02 AM
Default Re: Will hitting 13's be an easy task? (K20CIVIC007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20CIVIC007 &raquo;</TD></TR><TR><TD CLASS="quote">1st of a u shouldint go all motOR!!..that sucks..why u think there called the 13 second CLUB..i rathere BOOST any DAY </TD></TR></TABLE>
shut up
Old Oct 10, 2006 | 03:09 AM
UNKNOWN_MEMBER's Avatar
Default Re: Will hitting 13's be an easy task? (BoostedJeff)
invest in a b16 or itr tranny.
Soda Popinski
Nov 21, 2005 07:24 AM
Captn. Save A Hoe
Oct 27, 2003 12:50 AM
Dramier
Nov 26, 2002 03:29 PM
Jockobo
Nov 8, 2002 05:57 AM
