compression ratios.
depends....daily/street driven or for track? modifications you plan to go with? Tuning will be key if you go low or high compression.
+1 for tuning making or breaking it if you want to go high comp N/A...
use this to calculate your ESTIMATED compression then go from there.... http://www.zealautowerks.com/
i would personally try to at least run 93 octane gasbut when you get over 11:1 you might want to think about tuning and higher octane gas
I'm assuming the question wasn't what will my compression be, its what kind of compression is streetable right?
Well, as said before, its all in the tuning...
I'm runing 12.7:1 compression on the street with 93 octane, daily driven never had a problem.. i've heard of cars running in the mid 13 compression areas.. so like said before, its all in the compression..
But the key to high compression is good cams, with high compression when you make things flow better, you see bigger results
Also note.....dynamic compression will depend on the cam choosen and will have atleast some small part to do with whats streetable.
Mad Cow Disease
May 20, 2004 11:30 AM
