Oil Pan Drain Plug Stripped!!!! What now?????
Old Nov 20, 2006 | 05:02 PM
dbailey's Avatar
Default Oil Pan Drain Plug Stripped!!!! What now?????
Guys I'm not sure if this is place for this question but it said motor stuff so that's why I came here. I just bought a 90 Civic sedan with the 1.5 stocker in it and when I went to change the oil I found that the last person that changed it must have cross threaded the bolt. I bought a new bolt hoping that was all it was. NOT! The threads in the pan are stripped, too. Does anyone know of a bolt that is made for such situations that is sold or any way to fix it without having to go thru the hassle of replacing the pan? Thanks for any suggestions!
Old Nov 20, 2006 | 05:04 PM
Combustion Contraption's Avatar
There is a kit called 'sure seal' that most honda dealers have, where you can tap the pan for an oversized bolt. Then instead of a crush washer, you run an o-ring on the special bolt. but you only tq it to like, 20 ft/lb if that. If your worried about shavings in the pan, just leave the bolt out after you tap it, and pour some freash oil in the engine, just letting it run out the pan to clear out the shavings.
Old Nov 20, 2006 | 05:06 PM
dbailey's Avatar
Default Re: (Combustion Contraption)
Oh dude! IF that is the case, that would be awesome! Do you think Carquest or a place like that would have it or would I have to go to the dealer for it?
Old Nov 20, 2006 | 05:20 PM
dbailey's Avatar
Default Re: (dbailey)
Anybody know of anything else that works or is available?
Old Nov 20, 2006 | 06:24 PM
Uncle Willie's Avatar
(1.) Oversized plug with a piggy back plug. Basically its 2 plugs in one. It does take ALOT longer to drain tho.
(2.) Pan Saver (universal)- Pic tells it all. It will make a mess when you drain ur oil since it wont be a controlled stream. Ur hand will also get covered in oil.
Old Nov 20, 2006 | 06:44 PM
dbailey's Avatar
Default Re: (Uncle Willie)
Where can you get one of those piggy back ones?
Old Nov 20, 2006 | 06:50 PM
Auto parts store or
http://www.plews-edelmann.com/...=2516
Old Nov 20, 2006 | 07:31 PM
Cheeech's Avatar
Craftsmen sells a strip bolt remover set for $19.99, i have one and it saved me a couple times.
Old Nov 20, 2006 | 07:44 PM
The bolt is not the problem, the pan is.
Old Nov 20, 2006 | 07:52 PM
Cheeech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">The bolt is not the problem, the pan is.</TD></TR></TABLE>
Oh sry i misread the title....im not all here tonight haha
Old Nov 21, 2006 | 06:07 AM
dbailey's Avatar
Default Re: (CheechJDM)
I found out this morning that CarQuest Auto Parts sells a tapered oversize bolt for situations just like this for $2.64 each. THANK GOD! Thanks to all for your insight/suggestions guys!
Old Nov 21, 2006 | 11:31 AM
jacobolito's Avatar
get a new pan done deal
liquidx
Aug 8, 2010 03:58 PM
Spithead051
Dec 17, 2008 03:53 PM
dbailey
30
Nov 21, 2006 05:06 PM
Utilitarian
Mar 16, 2006 07:47 AM
MechEng
Oct 21, 2005 12:14 PM
