Hub and Bearing Removal (Front)
Old Nov 20, 2006 | 03:47 PM
Timberland237's Avatar
Default Hub and Bearing Removal (Front)
I only have a haynes manual and well they basically tell you to take it to a shop to get it done and well i'm a Machinist and at my shop we have all the necessary tools so can anybody give me a little tutorial on how to remove this hub and bearing i have both of them taken off the car nothing left on it but the hub and bearings what do i do next? thanks in advance
Old Nov 20, 2006 | 03:52 PM
Mario_D's Avatar
Default Re: Hub and Bearing Removal (Timberland237)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timberland237 &raquo;</TD></TR><TR><TD CLASS="quote">I only have a haynes manual and well they basically tell you to take it to a shop to get it done and well i'm a Machinist and at my shop we have all the necessary tools so can anybody give me a little tutorial on how to remove this hub and bearing i have both of them taken off the car nothing left on it but the hub and bearings what do i do next? thanks in advance</TD></TR></TABLE>
Hub bearing removal
All you need to know. Search the sticky post up there.
m-
Old Nov 20, 2006 | 04:04 PM
Default Re: Hub and Bearing Removal (Mario_D)
I posted because i looked there and they don't explain this particular disassembly..so good help would be appreciated, i'm not a newbie so.
Old Nov 20, 2006 | 07:04 PM
Mario_D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timberland237 &raquo;</TD></TR><TR><TD CLASS="quote">I posted because i looked there and they don't explain this particular disassembly..so good help would be appreciated, i'm not a newbie so.</TD></TR></TABLE>
Did you click that link? That is my how to remove a wheel bearing and hub assembly from a front suspension spindle.
You will need a press, some shim stock, arbor plates, and you will be set. Check that link I sent. If you have questions about it, PM me.
m-
taylorjohnson11
Nov 14, 2007 07:40 PM
DC_RaceR
Apr 26, 2006 04:05 PM
low430
Aug 29, 2005 08:32 AM
CRX_Control
Apr 24, 2005 12:40 PM
RedHatch.eh
Aug 11, 2004 05:27 PM
