Suspension & Brakes Theory, alignment, spring rates....
dropped LCAs?
Old Nov 20, 2006 | 03:18 PM
EFing_bmxED's Avatar
Default dropped LCAs?
i remember seeing some lower control arms (i think they were lcas) that dropped the car 1.5 inches on stock suspension. ive searched for lcas on here but now im thinking they were another part.
sound familiar to anyone?
thanks!
Old Nov 20, 2006 | 06:46 PM
PIC Performance's Avatar
Default Re: dropped LCAs? (BMX_EJ2)
I think you are talking about the front knuckles, not LCA's, that basically shortened the upright so the car sat lower without putting your axles at odd angles as would happen with traditional lowering methods. I forgot the name of them, maybe someone can chime in with that. They were powdercoated all sorts of different colors.
Old Nov 20, 2006 | 08:27 PM
dohcdelsol's Avatar
Default Re: dropped LCAs? (PIC Performance)
is that changing the caster of the car??? never heard of this before
Old Nov 21, 2006 | 03:41 AM
kiddcarbuff's Avatar
drop spindles, or knuckles i forget, alot of mini truck guys use them to drop the truck low w/out bags
Old Nov 21, 2006 | 04:06 AM
dAng! nobody knows what im talking about?
Old Nov 21, 2006 | 05:32 AM
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMX_EJ2 &raquo;</TD></TR><TR><TD CLASS="quote">dAng! nobody knows what im talking about? </TD></TR></TABLE>
I know. But i'll have to find it.
Old Nov 21, 2006 | 09:46 AM
hayabusa160's Avatar
i think dropzone made them they made the shorter forks and a special rear lca that lower the car.
i dont think they make them anymore.
edit: suspension techniques made them.
Old Nov 21, 2006 | 10:49 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">I think you are talking about the front knuckles, not LCA's, that basically shortened the upright so the car sat lower without putting your axles at odd angles as would happen with traditional lowering methods. I forgot the name of them, maybe someone can chime in with that. They were powdercoated all sorts of different colors.</TD></TR></TABLE>
Anything that lowers the car, will change the axle angle. The tire size remains constant and the axle attaches at the same height, but the chassis has been lowered in comparison. This will change the axle angle the same as a traditional lowering of the same amount.
However, with a drop knuckle, your suspension geometry will stay the same. As long as all dimensions except for the axle location remain the same, no changes to camber, caster, bumpsteer, etc...
Old Nov 21, 2006 | 11:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah I remember those from back in the day. I remember seeing a white 96-00 Civic 4-door with them in Super Street mag back in like 98 or 99. They were called DropForks and ProArms from Suspension Techniques (the car division of the BellTech truck suspension company).
Pretty trick items, although the LCA's had no swaybar attachment points.
Old Nov 21, 2006 | 08:25 PM
Default Re: dropped LCAs? (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">i think dropzone made them they made the shorter forks and a special rear lca that lower the car.
thats them!!! thanks
Old Nov 22, 2006 | 06:37 AM
Bakeoff's Avatar
You can also look into these...
http://www.heldmotorsports.com/Honda/index.htm
Old Nov 22, 2006 | 07:40 AM
Community Builder
Default Re: (Bakeoff)
I've seen those, but haven't seen any reviews or anyone who has actually used them.
Looks like a pretty good idea, all suspension components would retain the same angles as it did at stock height with stock components. Then if you wanted to you could use just a mild lowering spring to get a more extreme drop, but with minimal effects on suspension components.
Old Nov 22, 2006 | 07:43 AM
kaiba's Avatar
Default Re: (PatrickGSR94)
Thats it. That the one i was trying to look for.
Old Nov 22, 2006 | 09:25 AM
DFW's Avatar
DFW
Default Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I've seen those, but haven't seen any reviews or anyone who has actually used them.
http://www.heldmotorsports.com...2.jpg
Has anyone used those yet?
Old Nov 22, 2006 | 10:14 AM
FalkenSiR's Avatar
Default Re: (DFW)
I wouldn't want to use the 92-02 civic knuckle in my 95 civic.
Old Nov 22, 2006 | 10:30 AM
TunerN00b's Avatar
Lowering a 92-95 or 94-01 Integra the "traditional" way, we seem to run out of suspension travel before the tire drags against the fender. With a drop spindle like this, when during the suspension travel will the tire contact? Is anyone here a suspension engineer? Can anyone say that roll center, instant center, camber curve, etc..., are better with the control arms in their stock position or better for handling in a lowered position? Lowering a car without changing suspension angles sounds like a good idea at first, but there can always be unforseen consequences.
Example:
Where is the attachment point for the toe link? And is it just me, or does the RTA bushing seem like it wouldn't allow the same range of motion that the stock unit does? Similar to how polyurethane RTA bushings will bind.
Old Nov 23, 2006 | 05:53 PM
nWilk666's Avatar
Default Re: (TunerN00b)
suspension techniques made a nice pair of droped lcas and drop forks
Old Nov 23, 2006 | 06:09 PM
suspendedHatch's Avatar
You are tripping. The only thing these do is move the hub upwards. Well besides reducing weight. Compared to traditional lowering methods, there are almost no side effects (except ground clearance of course). Just stick to your lowering springs and aftermarket rear LCAs.
Old Nov 23, 2006 | 09:01 PM
408wdy's Avatar
im gonna contact those guys and see how much they are. if reasonable i will buy them n try it out
Old Nov 24, 2006 | 03:03 PM
kcjohnnyboy's Avatar
only if they still had those dropforks still made... i would like them for my ef... it would also be great if they brought it back and continued to make them
if anyone has a set for sale for a reasonable price...lmk
Old Nov 24, 2006 | 09:28 PM
Default Re: (408wdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 408wdy &raquo;</TD></TR><TR><TD CLASS="quote">im gonna contact those guys and see how much they are. if reasonable i will buy them n try it out </TD></TR></TABLE>
lmk how they turn out. im prolly gonna try em out too
Old Nov 29, 2006 | 10:06 AM
DFW's Avatar
DFW
Default Re: (BMX_EJ2)
Any news on these?
Old Nov 29, 2006 | 03:44 PM
dvp's Avatar
dvp
Default Re: (DFW)
Those spindles make the ball joint pretty damned close to the tire. Plus they cost as much (almost) as a new suspension does. $500+. Lowering is one thing, body roll and performance is another.
kcari
Suspension & Brakes
Aug 17, 2007 08:52 AM
Run Away
11
Feb 1, 2007 11:07 PM
boostedpleasure
Jun 30, 2006 04:06 PM
xx3xil3xx
Nov 12, 2005 05:25 PM
OoHiTzToMMy
10
Mar 24, 2004 10:08 PM
