is there suppose to be a gap at the bottom of the wg valve?
Old Nov 20, 2006 | 02:05 PM
SPOON_BeIgHtEeNsEe's Avatar
Default is there suppose to be a gap at the bottom of the wg valve?
on my tial wg there seems to be a gap at the bottom of the valve... is there suppose to be a gap or not? i never really paid any attention when i first bought it brand new...
Old Nov 20, 2006 | 02:15 PM
Schister66's Avatar
Man U FTW
no, you're supposed to use a fire ring
Old Nov 20, 2006 | 02:29 PM
tdo's Avatar
tdo
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">no, you're supposed to use a fire ring</TD></TR></TABLE>
that ring will block that gap
Old Nov 20, 2006 | 04:14 PM
A.E Motoring's Avatar
Default Re: (tdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">
that ring will block that gap </TD></TR></TABLE>
Old Nov 20, 2006 | 10:29 PM
Default Re: (Dual Cam Racing)
theres still a small gap even tho with the ring in
Old Nov 21, 2006 | 05:11 AM
slow poke's Avatar
Default Re: (SPOON_BeIgHtEeNsEe)
Show us a pic!
Old Nov 21, 2006 | 08:00 AM
b18sihatch's Avatar
Default Re: is there suppose to be a gap at the bottom of the wg valve? (SPOON_BeIgHtEeNsEe)
pics
Old Nov 21, 2006 | 08:36 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">theres still a small gap even tho with the ring in</TD></TR></TABLE>
There shouldn't be.
The ring should be just big enough so it sticks out the bottom a hair, then when you torque the wastegate to the manifold it pushed on the fire ring a bit, which pushes up on the valve a bit, so you get a good seal.
Maybe it's possible that your fire ring is worn and you need a new one??
Old Nov 21, 2006 | 08:38 AM
B18EG6's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">There shouldn't be.
Maybe it's possible that your fire ring is worn and you need a new one??</TD></TR></TABLE>
Its also possible that the valve was seated into the top part of the WG a little too far.
I noticed this was possible with my 35mm Tial. I had to rotate the plate with the side fitting so it didnt hit my hood, and in the process I noticed that the valve was held in by allen set screws and was able to be pushed in just a little too far.
Old Nov 21, 2006 | 11:16 AM
notoriousB's Avatar
Default Re: (B18EG6)
perhaps the OP installed the fire ring upside down so the WG valve isn't seating into it? just a thought.
Old Nov 21, 2006 | 10:29 PM
Default Re: (notoriousB)
gap is not big but i can still see light... ill get pics tomorrow...
JDMTuner4Life
Apr 26, 2007 06:56 PM
Rene M
Apr 1, 2007 12:14 PM
midwesta
Nov 20, 2005 11:20 AM
steve0unce
Nov 25, 2004 03:10 PM
BlueR
Apr 1, 2004 12:55 AM
