SRS light ON
Old Nov 20, 2006 | 12:57 PM
b16a4's Avatar
Default SRS light ON
Hello all,
I have passed thru some flood water, and as a result. my SRS lights wont go OFF.
i did the SRS reset proceedure, and it still lights.
i checked the 10AMP fuse, and it was blown, replaced and did srs reset again.
still wont go off.....
is there a way to pull the CODE to see whats causing the problem?
thanks guys
Old Nov 20, 2006 | 07:21 PM
igotthaspirit's Avatar
Default Re: SRS light ON (b16a4)
only way to retreive the srs code is either to goto a dealership or if you can find someone with a badass snap on scanner that can pull the code. You will probably have to end up replacing the SRS unit.
deanwashere
Jul 25, 2018 04:28 AM
lonis
Honda Civic (2006 - 2015)
Apr 8, 2017 09:46 AM
debbabi
Apr 1, 2016 11:09 AM
villaninblack
May 20, 2009 10:08 PM
97RSTEG
Honda Civic (2001 - 2005)
Jun 24, 2006 12:10 PM
