raised hood... fog effects?
i plan on doing the hood pop ONLY because the hood rubs on the valve cover. only plan on using 1 washer which wont raise the good too much.
what i want to know is if it will affect the fog characteristics of the windshield in the winter time?
If the valvecover is rubbing on the skeletal support (which I assume it is), you're better off bending it to create clearance, rather than raising the hood with washers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If the valvecover is rubbing on the skeletal support (which I assume it is), you're better off bending it to create clearance, rather than raising the hood with washers. </TD></TR></TABLE>
Or cutting out a section of the skeleton itself.
how exactly is bending done?
i was thinking of hammering the part that rubs. its not a big section but it annoys me. but if i raise the hood, it can help get rid of heat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 »</TD></TR><TR><TD CLASS="quote">how exactly is bending done?</TD></TR></TABLE>
Go get a spoon out of your kitchen. Hold each end in one hand. Then bring your hands together in a downward motion.
Isn't physics great?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 »</TD></TR><TR><TD CLASS="quote">i meant the hood.
Just take a dremel or skillsaw with a cutting wheel or metal blade, and remove the part of the ribbing that's rubbing. Problem solved. Or be super gay-dee-em and pop your hood.
</TD></TR></TABLE>Just take a dremel or skillsaw with a cutting wheel or metal blade, and remove the part of the ribbing that's rubbing. Problem solved. Or be super gay-dee-em and pop your hood.
i was thinking of hammering the part that rubs. its not a big section but it annoys me. but if i raise the hood, it can help get rid of heat</TD></TR></TABLE>
Yes, just shape it with a hammer. You can cover the area with a few layers of duct tape first to prevent excessive damage to the paint. Very simple, and there should essentially be no loss in the integrity of the skeleton.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">so rather than raise the hood 1/8 inch you would rather bend your hood right across the middle and therefore decrease the structural integrity of it?</TD></TR></TABLE>
Please explain how reshaping the skeleton slightly to allow clearance for the valvecover will "decrease the structural integrity" of the hood.
