Suspension & Brakes Theory, alignment, spring rates....
Weird TEIN Basic Damper problem on a civic hatch
Old Nov 20, 2006 | 08:53 AM
Turbo EH2's Avatar
* B A N N E D *
Default Weird TEIN Basic Damper problem on a civic hatch
Heres the deal, my car rode straight and the alignment was perfect when i had these basic dampers set all the way up (so it looked stock) Then i put new rims on my car and slammed it a good 3 inch or so. Both sides of the adjuster sleeve is in the same position however the cars height on the passenger side is higher by 1/2 inch. So i lowered the passenger side accordinly but now the cars alignment is way off... SO how do i actually set the ride height? I am measuring from the fender to the middle of the wheel. Do i make sure the car is level then get an alignment afterwards? Thanks in advance
Old Nov 20, 2006 | 07:31 PM
Turbo EH2's Avatar
* B A N N E D *
Default Re: Weird TEIN Basic Damper problem on a civic hatch (Turbo EH2)
bump
Old Nov 21, 2006 | 07:22 AM
EJ2-Fluffy's Avatar
remember whatever you do to one side of the suspension it will change the other side due to the suspension geometry of the car.
Old Nov 21, 2006 | 08:31 AM
Tuesday Club's Avatar
Default Re: Weird TEIN Basic Damper problem on a civic hatch (CRX-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">remember whatever you do to one side of the suspension it will change the other side due to the suspension geometry of the car.</TD></TR></TABLE>
Get your ride height even, then get another alignment....Every time you change something suspension-wise, you need to get the car re-aligned.
Old Nov 21, 2006 | 12:36 PM
TunerN00b's Avatar
Default Re: Weird TEIN Basic Damper problem on a civic hatch (Tuesday Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesday Club &raquo;</TD></TR><TR><TD CLASS="quote">Get your ride height even, then get another alignment....Every time you change something suspension-wise, you need to get the car re-aligned. </TD></TR></TABLE>
The part about getting an alignment is completely true. However, quit trying to get the car even left to right. Thats the worst thing you can do to the handling of the car.
Our cars are not even left to right stock, as the weight distribution isn't 50/50. Trying to lower the higher (lighter) side, will just place even more weight on the already heavier side, as the spring there tries to hold the car up with less help from the lighter side.
Check out any race prepped fwd Honda that has been corner balanced. It won't be even left to right. In fact, when I had mine done, they ended up lowering the already lower side, to help balance out the weight distribution.
Old Nov 21, 2006 | 08:20 PM
rip94delsol's Avatar
Default Re: Weird TEIN Basic Damper problem on a civic hatch (TunerN00b)
TunerN00b
Where did you get your car corner balanced, im in socal and need to get that done!
riceforlife
Dec 31, 2007 02:00 AM
thomst4R
Suspension & Brakes
Jun 6, 2005 07:44 AM
SPOON DC2
Aug 17, 2004 12:24 PM
urquidezj
Apr 5, 2004 11:09 AM
jdmjeff
46
Jan 21, 2004 05:55 PM
