is this setup worth the money???
Old May 8, 2002 | 04:40 PM
justanotherslowcivic's Avatar
Default is this setup worth the money???
-Stage 2a high compression all motor block LS Block $1400
-VTEC head , tapped for oil lines, resurfaced, upgraded valve springs and retainers,
valve job $1100
-Oil line fittings $100
-Skunk2 Stage 2 cams, $775
-Cam gears $220
-Head gasket $60
-ARP head studs $155
-timing belt $55.00
-Hydro tranny $750
-ECU, P28 chipped or GSR $300
Intake manifold gasket $15
Old May 10, 2002 | 10:03 PM
EF_LSVtec's Avatar
Default Re: is this setup worth the money??? (tjtice)
More power is always worth the money...One good lesson I've learned is you can always get it somewhere cheaper. Brand new Skunk2 cam gears, I got em for $120 (pair), Built LS Block w/ ITR pistons, shotpeened rods, all balanced for $900, parts included. $350 for head porting (GSR), ITR valvesprings, valve guides, retainers about $320, $550 for CTR cams. I get cheap OEM parts because my brother works as a parts person at an Acura dealership. I think he gets 40% discount...I can tell you some overpriced parts too that I paid along the way. Like a JDM Y1 tranny for $650, what a ripoff...As long as it performs well, I'd say it's always worth it.
Old May 11, 2002 | 06:47 AM
Ricey McRicerton's Avatar
Default Re: is this setup worth the money??? (EF_LSVtec)
honestly, if you have to ask, its not to you. Dont worry about everyone else's opinion, keep doing your homework and keeping your eyes open, you can find better prices, but it all depends on how fast you want to go.
Old May 12, 2002 | 07:49 AM
Bleed Black's Avatar
Default Re: is this setup worth the money??? (Ricey McRicerton)
Everything looks about right, but get a chipped P28 from Kenji on this board for 225-250 shipped.
jaw_kn33
Jan 30, 2013 11:56 AM
ivan93egreppin210
22
May 6, 2011 05:08 PM
hebijake
Mar 10, 2006 03:47 AM
NightmareApex
Oct 24, 2005 09:36 AM
turbodsmpower
Aug 4, 2003 05:31 PM
