Turbo GSR question: no vtec?
Old Nov 20, 2006 | 07:35 AM
Jcards26's Avatar
Default Turbo GSR question: no vtec?
I recently turboed my 2000 gsr over the summer. However i have done no tuning so far it is just running on a basemap getting ready for uberdata. Its a stock b18c1 with a greddy 18g. after finishing the project, i noticed that there were little bits of oil dripping from the return line. Nothing serious just a little amount. I figured it was just loose so i attempted to tighten it. Another problem is that while running the car looses power where vtec should be hitting. i am guessing that this is because the car has not been properly tuned yet. but i found it odd that vtec is not even engaging anymore!!! the car runs fine when on. i know this topic has been discussed before, but i didnt quite find some case exactly like mine. let me know what you think. sorry for the giant pic
here are some pics of the finished product
Old Nov 20, 2006 | 09:19 AM
95dc2teg's Avatar
Default Re: Turbo GSR question: no vtec? (Jcards26)
i cant see anything the picture is too small.......
Old Nov 20, 2006 | 11:30 AM
Schister66's Avatar
Man U FTW
Once i boosted my car i had the same problem, but it was because my VSS became unplugged somehow.....other than that, i'm not sure what's going on....it could be your basemap
Old Nov 20, 2006 | 12:46 PM
aaronISthrowed's Avatar
Default Re: (Schister66)
I would'nt even try to hit vtec if i wasnt tuned.
Old Nov 20, 2006 | 12:49 PM
whiteef8's Avatar
Default Re: (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">I would'nt even try to hit vtec if i wasnt tuned. </TD></TR></TABLE>
Old Nov 20, 2006 | 12:52 PM
david@didrace.com's Avatar
The only proper way to check if VTEC is operating correctly is to bring the car in 4th gear up to redline. If the rev limiter acts like normal then everything is OK.
Old Nov 20, 2006 | 01:20 PM
Jcards26's Avatar
Default Re: Turbo GSR question: no vtec? (david@didrace.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com &raquo;</TD></TR><TR><TD CLASS="quote">The only proper way to check if VTEC is operating correctly is to bring the car in 4th gear up to redline. If the rev limiter acts like normal then everything is OK. </TD></TR></TABLE>
Thanks for the help!!!!!
Old Nov 24, 2006 | 09:04 PM
alex_s817's Avatar
maybe this is a dumb answer but it may have been overlooked. make sure you have plenty of oil as vtec will not engage if you dont. i had a friend that spent hours trying to
figure out why his vtec wouldnt work and it was because he had the wrong dipstick in there which was to short. good luck getting it fixed
Old Nov 24, 2006 | 09:23 PM
beasty=eg's Avatar
yo i got the same problem on my d16z6 with the same kit 18g thats is what my is doing. it boost up but like at 5k it brake's up and lose power i need help
Old Nov 24, 2006 | 09:34 PM
ek99's Avatar
Default Re: (beasty=eg)
I had the same issue with my b16 turbo and tuning fixed my issues. Before tuning, my car used to idle rough and bog in vtec, seems that the base-map was way off according to my tuner.
Old Nov 25, 2006 | 06:58 AM
2point2's Avatar
I burned 16 bins before I attempted to hit VTEC lol.
Old Nov 25, 2006 | 09:04 AM
ngogsr's Avatar
your car wont run that great w/out tune, pls what size inj are you running? those 310cc? that greddy comes w/suck get some 450cc or larger
Old Nov 27, 2006 | 08:11 AM
Jcards26's Avatar
Default Re: (ngogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngogsr &raquo;</TD></TR><TR><TD CLASS="quote">your car wont run that great w/out tune, pls what size inj are you running? those 310cc? that greddy comes w/suck get some 450cc or larger</TD></TR></TABLE>
yea i have dsm 450's in there. i think the tuning might be part the problem. as alex_s817 said regarding the oil level, i think the oil level is high. could this cause it? i totally forgot that i added to much in hopes that it would slowly burn off. does anyone know if over the line on the dipstick will cause no vtec?
Old Nov 27, 2006 | 10:25 AM
ek99's Avatar
Default Re: (Jcards26)
No, your oil level will not stop your vtec from working unless its really low. You can be a quart low or over and vtec will still work. I've done both
Old Nov 27, 2006 | 10:36 AM
Muckman's Avatar
Moderator in Chief
The tune isnt part of the problem it IS the problem. Or lack there of. I see your local too. PM or AIM me and maybe I can help you out with your tuning problems.
Old Nov 29, 2006 | 10:35 AM
Jcards26's Avatar
Default Re: (Muckman)
ok so im thinking im just lacking a good tune. i was planning on getting it tuned this spring because i already put it away for the winter. i also bought a wideband 02 sensor
Old Dec 4, 2006 | 10:24 AM
Jcards26's Avatar
does ne one know about an oil leak if the turbo is blown or not? I notice sometimes a little oil on the intake trim of the turbo. The turbo was used with 15k on it and a slight shaft play.
Old Dec 4, 2006 | 12:53 PM
Muckman's Avatar
Moderator in Chief
What size oil feed line do you have to the turbo? Hows your oil return look? And are you using an oil feed restrictor?
Old Dec 4, 2006 | 12:57 PM
93turbo16's Avatar
What ecu do you have in there?
Old Dec 4, 2006 | 03:48 PM
Jcards26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">What size oil feed line do you have to the turbo? Hows your oil return look? And are you using an oil feed restrictor?</TD></TR></TABLE>
The oil feed line kit i bought was off of fast-turbo.com. it was for the greddy 18g. I do not know what the size is. my oil return looks ok it makes a big turn, and sometimes oil drips from the oil return line right where it goes into the pan. there has to be a slight leak somewhere. I dont think its an oil restrictor. For ecu... i am using a chipped p28.
Old Dec 4, 2006 | 03:56 PM
bluteggy00's Avatar
you boost you tune. if not its deff gonna run like crap. my boy boosted his delsol and had the same problems till tunning time and it ran perfect after.
Shaun
Aug 3, 2006 09:24 AM
MikeTV
Apr 5, 2004 10:35 PM
1meangsr
Apr 18, 2003 07:49 PM
MikeMAN
Mar 8, 2003 02:23 PM
redteg1
Oct 9, 2002 04:33 PM
