intermittant starting issues
Old Nov 19, 2006 | 11:01 PM
egcivic's Avatar
Default intermittant starting issues
okay, so ive had starting issues for a little while, not too often but once in a while
usually everything starts fine, but once in a while ill go to start it, ill let my fuel pump prime and then the check engine turns off and i turn it to start and just a click and everything goes dead.
usually i can just fool around with the battery wires, and it will start up fine
but now i went to check a loose connection on the battery and it still wont start. i tried jumping the car but it still wont start.
so i thought maybe i blew the fuse or shorted the ecu. well i checked all my fuses pertaining to the ecu and stating and electrical, they all look fine.
so i was wondering if anyone can diagnose my problem, im leaning towards main relay becuase when everything dies out, i try to turn on my hazards and three is a buzzing from under the steering column by the fuse box, and i know thats where the main relay is
and help is appreciated
thanks in advance
Old Nov 19, 2006 | 11:07 PM
egcivic's Avatar
Default Re: intermittant starting issues (egcivic)
oh yes and if i might add when i try to start it and it dies, it clicks if that helps
it sounds a lot like this problem
https://honda-tech.com/zerothread?id=1128975
but i tried even jumping it and i didnt get any results
Old Nov 20, 2006 | 06:24 AM
egcivic's Avatar
bump this
my car started this morning fine
only difference was about 30 degree in cold temperature
Old Nov 20, 2006 | 05:32 PM
egcivic's Avatar
noone knows?
Honda_bed
Apr 22, 2014 12:22 AM
smbignick
Aug 18, 2013 01:47 PM
FlewByU352
Sep 22, 2011 12:15 PM
markchans
Dec 21, 2005 11:43 AM
junkyardRx
15
Apr 26, 2004 03:04 AM
