gt35r or gt40 for B16 ??
ok here my situation iam building a b16 sleeved with 81.5 mm bore fully ported head over sized valves full valvetrain and everything is port martched done by gude iam looking to run 30 -35 psi are our goals "track car only " just picked up the aem ems for it which turbo would ur recomend for a b16 that has ross pistons and eagle rods acl bearings and all arp hardware would u reccomend full races gt35r or the garret t3/GT40 ?? thanks for the help in advance just need to get some opinions before i order the turbo and manifold i dont wanna use nitrous on this application just wondering which would have the quickest spool and be best for my setup
also running BLOX turbo cams if that makes a difference
thanks u guys i was thinking the gt40 would be a little on the big side the block is still in the machine shop but once the set up gets finished i will post pics
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgeek133 »</TD></TR><TR><TD CLASS="quote">ok here my situation iam building a b16 sleeved with 81.5 mm bore fully ported head over sized valves full valvetrain and everything is port martched done by gude iam looking to run 30 -35 psi are our goals "track car only " just picked up the aem ems for it which turbo would ur recomend for a b16 that has ross pistons and eagle rods acl bearings and all arp hardware would u reccomend full races gt35r or the garret t3/GT40 ?? thanks for the help in advance just need to get some opinions before i order the turbo and manifold i dont wanna use nitrous on this application just wondering which would have the quickest spool and be best for my setup
also running BLOX turbo cams if that makes a difference </TD></TR></TABLE>
i think everyones missed this but your title and your post list 2 different turbo's...in your title you say GT40 and your post says t3/gt40 aka blowzilla....theres a big difference.
also running BLOX turbo cams if that makes a difference </TD></TR></TABLE>i think everyones missed this but your title and your post list 2 different turbo's...in your title you say GT40 and your post says t3/gt40 aka blowzilla....theres a big difference.
lol i did not even notice ..... i meant the gt40r i was reading on the blowzilla rite before i posted this sorry bout that i wanna stick with full race products my freind has had nothing but good expeirences with there products and customer service
and that head is gona suck on the 81.5mm bore.. big valves need big bore.
and gt40 is gona suck on a b16, it wont hit boost till probably 7000 rpms
I would go with the 35R over the 40R on a B16 cause you dont have enough displacement. So there for your powerband/ full spool would be about 6500rpm with the 40R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgeek133 »</TD></TR><TR><TD CLASS="quote">GT3767S why would u reccomend this turbo over the 35r ?? </TD></TR></TABLE>
Because spooltime from this turbo is just a litle bit slower but you will make more peak power. If you are building a a drag car it will be better..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgeek133 »</TD></TR><TR><TD CLASS="quote">hey i see u went 10.4 in ur hatch what turbo and what psi were u running ??? and the head is a built B16 head with blox turbo cams </TD></TR></TABLE>
T3/T67 H.O. went 10.4 on 23 lbs. Broke a sleeve when I ran it on 29 lbs but made 567whp on 29 psi.
if this is a track only car and you spool at 7000 which i dont agree with, you will still be ok it the trans and slick size selection is ok. If you go under 7k on the track with a built b16 bottom end and a built head you are messing up somewhere. Go with the gt40r and for additional spool time go with the full race divided twin scroll manifold. I have personally seen the spool diffenence when used with a 42r. My car spooled at 6500 with a full race topmount and an identical car spooled at 5500 with a twin scroll fullrace manifold. It should be just as significant with a slightly smaller motor and turbo.
hey can somone send me a link to prices and pics of this full race twin scroll manifold everyone is talkin bout i looked on full race and cant find it anywhere thanks in advance
i dont know that they have it on the web site but if you pm geoff he could get you some pics and a price. Or contact Tony1 and he can get you a price and possibly some pics.
ok change in build the block is sold and iam doing a 2.0 crower stroker kit.. pistons and rods and crank are for sale on honda-marketplace .... so now that i decided to go bigger would the gt40r be a problem at all to spool ?
