Hard to rotate cams by hand w/ ITR pistons
Old Nov 19, 2006 | 09:47 PM
bigsubs's Avatar
Default Hard to rotate cams by hand w/ ITR pistons
I just installed some USDM ITR pistons in my 97 GSR, after installing my head I found it veery difficult to tun the cams w/ a ratchet. I had a valve job done to the head and had them installed some ZEX /comp springs and steel retainers. Will the new spring rate in conjuction w/ the higher comp make it that difficult to rotate? also once I was able to get it to move a hair , it scratched my cams,only on the 1 and 3 piston. Also for the record the guys who did my head work said that I had bent my exhaust valves when my can jumped timing during a down shift
Old Nov 20, 2006 | 06:23 AM
s10cky's Avatar
Default Re: Hard to rotate cams by hand w/ ITR pistons (bigsubs)
well im not completly sure the problem. But did you properly torque the cam caps? your cams shouldnt have scratched.
Old Nov 20, 2006 | 07:23 AM
JDM_teh_WIN!!'s Avatar
Default Re: Hard to rotate cams by hand w/ ITR pistons (s10cky)
Why are you rotating your cams one by one with a ratchet? The timing belt is on and you are turning the motor over?
Old Nov 24, 2006 | 08:14 PM
Brick Top's Avatar
Default Re: Hard to rotate cams by hand w/ ITR pistons (JDM_teh_WIN!!)
when you turn just the cams and not the whole bottom end too, your jamming the valves right in to the piston. thats why they are hard to move.
Old Nov 24, 2006 | 08:33 PM
96typeR's Avatar
i have a built valvetrain and when i was re-timeing everything it was difficult to turn the cams also...but ur discribing it to be too hard....make sure and put assebly lube all over the cams or atleast tranny oil
Old Nov 24, 2006 | 08:43 PM
s10cky's Avatar
Default Re: Hard to rotate cams by hand w/ ITR pistons (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">when you turn just the cams and not the whole bottom end too, your jamming the valves right in to the piston. thats why they are hard to move.</TD></TR></TABLE>
not if the timing belt is installed.
Old Nov 25, 2006 | 01:36 AM
thehondaconnection's Avatar
Lol??!! I'm still waiting to hear this guys reply
Old Nov 25, 2006 | 03:38 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">
not if the timing belt is installed.</TD></TR></TABLE>
right but didn't say anything about that. said he was turning the cams with a ratchet. but who knows???? he needs to respond
Novtecdohc
Nov 22, 2006 11:28 AM
diagnostic
Jul 16, 2006 03:38 PM
BlueTeg
Jan 25, 2004 04:01 PM
B18C
Jul 30, 2003 03:30 PM
JDMvtecDRAGSTA
Apr 18, 2002 03:28 AM
