squeaking nosie when i turn...
yupp makes some squeaking noise when i turn my wheel left like almost half way... i'm not sure wat it is, so hoping to get some ideas about wat it MIGHT be so i'll know wat to look for when i look thanx guys
I've had a similar problem. It squeeks when I turn to left alittle bit or a lot, and also when I am going straight really slow, and if I turn the wheel all the way to the right. I was thinking it may be rubbing on something but it sounds like a rubbery sound so I was gonna rotate my tires to see if its them. Btw its from my right front tire.
i had a rubbing noise at that made a squeek when i would turn. it was the piece of robber at the bottom of the steering colum inside the cabin. it's right around where the joint comes in from the rack. i just sprayed some white lithium and viola, problem solved.
mine would make a weird squeek noise when i would pull into parking spot(or at least thats when i would hear is because i would be going slow.) Turned out to be an axle. If u cant see anything that would be rubbing or and other visual damage...its more than likely an axle. oh......maybe check ur steering too? How does the car handle as far as steering and when ur just head straight down the road. I felt my steering wheel shaking a lot at higher speeds. After a new axle, it drove perfect.Good luck.
is it a rubber or metal sound. cus if its a metal sound. try just doing the drive shaft bolt up the littleest bit. it cured mine and a few others
how u find out wat it is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrs2ksi »</TD></TR><TR><TD CLASS="quote">mine would make a weird squeek noise when i would pull into parking spot(or at least thats when i would hear is because i would be going slow.) Turned out to be an axle. If u cant see anything that would be rubbing or and other visual damage...its more than likely an axle. oh......maybe check ur steering too? How does the car handle as far as steering and when ur just head straight down the road. I felt my steering wheel shaking a lot at higher speeds. After a new axle, it drove perfect.Good luck.</TD></TR></TABLE>
well mine drives perfectly find just that squeak when i turn but i'll check out the axle thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmyoo »</TD></TR><TR><TD CLASS="quote">is it a rubber or metal sound. cus if its a metal sound. try just doing the drive shaft bolt up the littleest bit. it cured mine and a few others
oo yea it sounds like metal i'll check that out too haha maybe i should just check everything on my car huh? lol aite thanx guys hope i solve it soon **** is bother me like krasie
</TD></TR></TABLE>oo yea it sounds like metal i'll check that out too haha maybe i should just check everything on my car huh? lol aite thanx guys hope i solve it soon **** is bother me like krasie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">if it does it when your going slow have a friend drive it and you walk right beside it and use your mechanics ear.</TD></TR></TABLE>
eyy good point haha
eyy good point haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stuie08 »</TD></TR><TR><TD CLASS="quote">tryinmg to fix the same situation.</TD></TR></TABLE>
o yea if u get it done before i do let me know wat you did... and if i get it done before you i'll post it
ajun217
Nov 12, 2014 08:25 AM
