stupid transmission question b18
Old Nov 19, 2006 | 07:11 PM
memorybox's Avatar
Default stupid transmission question b18
are the tranny cases the same for the b18b1/c1/c5? Can I buy a type-r or gsr rebuild kit and have a gsr/type-r tranny? or do i just need to swap gears and diff?
i tried searching but had no clue and just got lost
Old Nov 20, 2006 | 02:19 AM
SkRiBLaH's Avatar
Default Re: stupid transmission question b18 (memorybox)
the GSR and ITR have tapered roller bearings
the b18b1 trans has enclosed bearings.
thats teh only differancee
Old Nov 20, 2006 | 06:00 PM
Katman's Avatar
Default Re: stupid transmission question b18 (SkRiBLaH)
The gear ratios are not the same between B18B/B18C1/and B18C5.
Also the diff in a B18B tranny is exactly the same size diameter as a B16A tranny which is an overall smaller size than the B18C1/B18C5 diffs.
memorybox,
if you stick with a B18C1/B18C5 tranny casing you should be fine.
Swiftstar
Sep 29, 2009 01:07 PM
devang230
Oct 11, 2005 05:11 PM
greebler
Sep 21, 2003 07:34 PM
AJTEG
Jun 20, 2002 04:13 PM
EminemGSR
Apr 22, 2002 11:08 AM
