Getting out rusted cat bolts
How did u guys go about this ? Mine are soooo rusted its ridiculous. And i dont wanna force them and snap em. I sprayed them down with PB with no luck.
Ahaha, my CRV had some that were rusted solid and I just changed the cat today.
Had to get out the old angle grinder and cut all the bolts off. There's no way you will be able to undo them....they will strip before they turn. I had the weight of the whole car on some of my bolts (jack under the wrench) and they just rounded off.
Hopefully yours aren't that bad.
I got mine off with some PB Blaster, 6 point socket, and an impact...or did I use a breaker bar... either way, it took a long time. And I was lucky enough to have a lift, so I could stand under the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">I got mine off with some PB Blaster</TD></TR></TABLE>
PB Blaster FTMFW!
PB Blaster FTMFW!
I was lucky on 2 of mine a 1/2 inch impact got them off, the third, I cut an edge off with my dremel and a cutoff wheel, then a second edge, then I popped the nut off. I had to fix the threads up a lil bit, but it was better then having to put a whole new stud in there. Lucky my header came with new upper to lower bolts, and the old nuts from there fit the cat studs perfect.
lol im in this boat now...i cant get mine off pb blaster didint work i was at 100 psi with my impact no go...so my friend with his 1000 ft lb impact is coming over 2 morrow lol try that if not well ill pull out the dremel and torch...
Acidcrakker
Mar 3, 2008 08:46 PM
94B18B1Teg
Mar 15, 2004 11:05 AM
thats what i did with my crx when i had it rusted all took a torch to them came right out.
