b18c1 block?
Old Nov 19, 2006 | 06:27 PM
CeeJayy's Avatar
Default b18c1 block?
i have a 00 civic si and my buddy is selling a b18c1 block for dirt cheap. would it be a waste to put my b16a2 head on that block? would there be any improvments?
Old Nov 19, 2006 | 06:40 PM
vlc92189's Avatar
Default Re: b18c1 block? (CeeJay16)
people do a poor mans type r by taking a gsr block and using ab16 head with type r internals
Old Nov 19, 2006 | 06:44 PM
.Kevin.'s Avatar
Default Re: b18c1 block? (vlc92189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">people do a poor mans type r by taking a gsr block and using ab16 head with type r internals</TD></TR></TABLE>
wrong its an LS block and a vtec head.
Anyways there would not be enough gains to do the swap over. I believe the benefit would be more tq.
Old Nov 19, 2006 | 07:18 PM
Kafelatte's Avatar
like 10 more trq and hp. not worth it. buy the block and sell it.
Old Nov 19, 2006 | 07:24 PM
H9Omega's Avatar
Wow... seriously if you guys dont know what you are talking about please do not post. A b18c1 block mated with a b16 head is a "poor mans R" Ep_Kevin is reffering to an LS/VTEC setup.Now first things first when perfoming this swap it is ideal to change out the gsr pistons due to it lowering the compression raito due to the b16 head. You can use ITR/CTR/ or you can just swap over your pistons and it will make good power. Any more questions just sent me a message i will be more than gladly to help you choose the correct path.
CeeJayy's Avatar
Default Re: b18c1 block? (kay20adc2)
ok thanks
Old Nov 19, 2006 | 07:30 PM
.Kevin.'s Avatar
Default Re: (H9Omega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H9Omega &raquo;</TD></TR><TR><TD CLASS="quote">Wow... seriously if you guys dont know what you are talking about please do not post. A b18c1 block mated with a b16 head is a "poor mans R" Ep_Kevin is reffering to an LS/VTEC setup.Now first things first when perfoming this swap it is ideal to change out the gsr pistons due to it lowering the compression raito due to the b16 head. You can use ITR/CTR/ or you can just swap over your pistons and it will make good power. Any more questions just sent me a message i will be more than gladly to help you choose the correct path.</TD></TR></TABLE>
I was reffering to what the person above me stated. I was correcting him because people call the ls vtec a poor mans type R swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay20adc2 &raquo;</TD></TR><TR><TD CLASS="quote">like 10 more trq and hp. not worth it. buy the block and sell it. </TD></TR></TABLE>
No that is the stats on the complete motor change over. very wrong.
sivtechatchy
Mar 6, 2009 03:45 AM
219DAdriver
Oct 1, 2007 07:26 AM
j_DC2_m
Jul 13, 2006 09:07 PM
Lewcis
Jul 29, 2004 09:19 PM
Mickeyjay36
Apr 4, 2004 10:29 PM
