Tire size ?
Old Nov 19, 2006 | 05:39 PM
Ash81's Avatar
Default Tire size ?
I have a 97 prelude and the stock tire specs are 205/50/16.......... i just bought some tires that are 205/55/16 will these fit the car without any issue as in clearance wise/rubbing?.........and my car is not lowered or anything, its bone stock......any input would be appreciated
Old Nov 19, 2006 | 05:47 PM
InvaderTrax's Avatar
They'll fit fine, but your speedo will be off just a little bit
Old Nov 19, 2006 | 06:16 PM
Ash81's Avatar
Default Re: (InvaderTrax)
speedo?...(speedometer), when you say off a little bit..... what do you mean by that?
Old Nov 19, 2006 | 06:18 PM
Honda318dx's Avatar
Default Re: (Ash81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ash81 &raquo;</TD></TR><TR><TD CLASS="quote">speedo?...(speedometer), when you say off a little bit..... what do you mean by that?</TD></TR></TABLE>
He means that when your speedometer says a certain speed, you will actually be travelling at a <u>faster</u> speed.
I can't think of a good reason to increase the sidewall height beyond stock.
Old Nov 19, 2006 | 08:23 PM
Silver Surfer's Avatar
Default Re: (Honda318dx)
http://www.miata.net/garage/tirecalc.html
Speedometer reading with non-stock tire is 3.4% too slow.
When your speedo reads 60mph you are actually traveling 62.0mph
you will loose some quickness in acceleration
only benefit is that you will save mileage on your odometer......when you put 100 miles on your odometer you will have actually traveled 103.4 miles
Old Nov 19, 2006 | 09:41 PM
ethereal2pt2's Avatar
Default Re: (Silver Surfer)
sweet tire calc.
very handy.
Old Nov 20, 2006 | 09:33 AM
korney's Avatar
Default Re: (_BB6)
ok, so lets say I have the tire size= 185/70-14 (stock prelude S) and I upgrade to a 205/50-15 tire size; when going 60 mph I will be really traveling 62.82 mph? is that correct? because useing the tire calculator, the differnence is 4.7% So 60 x .047 = 2.82? So I would be going 62.82? is that right? sorry I really suck at math LOL.
Another question, if I have the rear tires at 195/55-15 and the front ones at 185/70-14, will there be a differnece as well?
Old Nov 20, 2006 | 10:08 AM
195/65/14
205/60/14
195/60/15
205/55/15
225/50/15
195/55/16
205/50/16
225/45/16
this covers pretty much all the sizes you should use on any stock 4th or 5th gen wheel to keep very close to the same overall diameter........and don't start chiming in with the 215 bullshit cause it's not closer
aznbigman
May 1, 2008 11:14 PM
Stockton
Nov 11, 2005 08:46 AM
URtaxes
Sep 20, 2005 03:10 PM
ludewithanh22
Jun 26, 2005 02:16 AM
razersharp
Sep 10, 2003 04:44 PM
