how to remove spray paint?
Old Nov 19, 2006 | 04:24 PM
JDM RHD eg6's Avatar
Default how to remove spray paint?
hey i picked up a civic hatchback...well heres the thing the car been sitting outside for a while and now....someone just painted my damn Door...anyone know how to remove this? My paint is still good....and i dont wanna miss it up...HELP ME OUT
Old Nov 19, 2006 | 04:27 PM
sasser43's Avatar
Default Re: how to remove spray paint? (JDM RHD eg6)
thats gonna be tough. usually ppl just repaint the areas.
Old Nov 19, 2006 | 04:32 PM
cambopheonix56's Avatar
Default Re: how to remove spray paint? (sasser43)
Mothers clay bar removes overspray, I do not know about large quantities.
Old Nov 19, 2006 | 04:43 PM
Default Re: how to remove spray paint? (cambopheonix56)
would it miss up my paint job?
Old Nov 19, 2006 | 04:45 PM
sasser43's Avatar
that wouldnt, but it might not remove all of the spray paint.
Old Nov 19, 2006 | 04:48 PM
i just got some imperial wetordry Grain 2000...would that work?
Old Nov 19, 2006 | 04:49 PM
jerbear!'s Avatar
yes it would but it would also dull your paint
Old Nov 19, 2006 | 04:50 PM
Default Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">yes it would but it would also dull your paint</TD></TR></TABLE>
omg i think it just did...anyway i can fix that? buffing it?
Old Nov 19, 2006 | 05:02 PM
Default Re: (JDM RHD eg6)
Thanks for the help guys...anyother things i can do to fix this problem?
Old Nov 19, 2006 | 05:15 PM
Eran's Avatar
HT White Ops
I'm not trying to be brutally mean here, just brutally honest:
It was retarded of you to sand your door without knowing what you were doing. You now need to take it to a body shop and PRAY you didn't go through your clear coat. They will attempt to sand again, then cut and buff. If you did burn your clear, you'll probably need the entire door repainted.
Good job.
Old Nov 19, 2006 | 05:23 PM
NOFX's Avatar
H-T White Ops
Default Re: (Eran)
I can't confirm this, but I searched online and found a few things...
http://www.freerepublic.com/fo...posts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Get a $5 can of GOOF OFF!
To you and all others with spray paint on cars... Before you go and get some high-priced paint job, I urge you to look under your kitchen sink for items that can save you money and damage to your paint job.
I had my green car stolen and the morons used RED household spray paint to try to disguise the car. It was recovered and the insurance totalled the car because they were to cheap to pay for a paint job. I bought the car back (you can do that in Michigan) since the body and engine were still good.
Under my kitchen sink, was a can of GOOF OFF that I used to get crayon off my walls. I sprayed some on the car, waited a minute and the spray paint wiped right off! So I bought three more cans and for $20 and some elbow grease, I had my car back... PLUS the $5,000 the insurance gave me.
You can get GOOF OFF in any grocery or hardware store and its only $5 a can and it doesnt harm your cars paint or finish.</TD></TR></TABLE>
Or here: http://www.impalahq.com/HowTo/Spraycan.html
He used an adhesive remover. Might as well try some things like this first. If you used chemicals on your car be careful. A lot of the things that will remove the spray paint can also damage your paint underneath.
Well, now you've probably dry sanded it and caused some decent damage yourself. i'd recommend looking into how much getting that part repainted might cost you.
More advice:
http://search.yahoo.com/search...x=wrt
Old Nov 19, 2006 | 05:38 PM
Default Re: (NOFX)
ok everyworks out great for me after all....btw what i did was a very good job hahha...the only thing you have to do is send it down with 2000 grain and buff it
Old Nov 19, 2006 | 06:16 PM
mattyv's Avatar
try autozone or pepboys for a clay bar and it should take it off or thinner made for car use
Old Nov 20, 2006 | 10:08 AM
KodSol's Avatar
Default Re: how to remove spray paint? (mattyv)
even if you did go through your clearcoat on the door, that can be fixed really easily. Just take like a 1600 grit sandpaper and sand the whole door just enough to where the clearcoat is all off. Then wipe it down and re-clearcoat it. i used to work at a dealership. the body shop manager told me to do that with my car that i painted myself.
pxsx
Aug 2, 2008 06:30 AM
MassScene
Mar 15, 2005 05:26 AM
MassScene
Mar 14, 2005 11:21 PM
trooper0641
Oct 11, 2004 12:48 PM
