B-SERIES SWAP HARNESS
Old Nov 19, 2006 | 02:32 PM
lCHaCHeel's Avatar
Default B-SERIES SWAP. HARNESS PROBLEM!!
OK WELL IM TRYING TO SWAP THIS LS I HAVE INTO A EG OF COURSE AND WELL THE SWAP I GOT CAME WITH NO HARNESS, SO I HAD TO FIND ANOTHER ONE. I BOUGHT ONE THINKING EVERYTHING WOULD BE COOL. BUT, NOW I DONT KNOW IF MAYBE I HAVE THE WRONG HARNESS(OBD2) NOT SURE HERE ARE SOME PICS OF THE PROBLEMS I CAME ACROSS AFTER CAREFUL INSPECTION. (FLAME IF U WANT HATE I DONT CARE JUST HELP ME PLEASE) I SEARCHED AND THE THREADS I FOUND DIDNT REALLY GIVE ME AN ANSWER.
NOT SO SURE IF THE COLORS WORK FOR YOU GUYS BUT THE YELLOW PLUG DOESNT FIT IN ANY OF THOSE NEITHER DOES THE GREEN
ALSO I NOTICED ALL THESE WIRES(RED BOX) ARE ON THE OPPOSITE SIDE SHOULDNT THEY BE ON THE OTHER SIDE BY THE TRANNY?? OR AM I WRONG??
I REALLYNEED SOME HELP HERE GUYS IM THINKING I BOUGHT THE WRONG HARNESS OR THE GUY GAVE ME THE WRONG HARNESS?? OR IS THERE I WAY I CAN JUST TAKE ALL THE WIRES APART AND SOMEWHAT MAKE A NEW HARNESS BY RUNNING ALL THE WIRES TO HUG THE BLOCK(LIKE WIRE TUCK)AND JUST REWIRE THETHE OTHER TWO YELLOW AND GREEN PLUGS. ALSO ALL THE OTHER PLUGS ON THIS HARNESS CONNECTED TO THE MOTOR EXCEPT THE VSS AND WHEN THE HARNESS IS PLUGGED TO THE MOTOR THE 3 BIG PLUGS(YELLOW AND GREEN) END UP BY THE DRIVERSIDE TOWER(WHERE THERE IS 2) AND THE TWO OTHER PLUGS END UP BY THE PASS. SIDE TOWER (WERE THERE IS 3)
Old Nov 19, 2006 | 02:58 PM
Luserkid's Avatar
Default Re: B-SERIES SWAP. HARNESS PROBLEM!! (lCHaCHeel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lCHaCHeel &raquo;</TD></TR><TR><TD CLASS="quote">
That pic say it all. You have a RHD harness or have it backwards.
Old Nov 19, 2006 | 03:20 PM
EJgsr's Avatar
Default Re: B-SERIES SWAP. HARNESS PROBLEM!! (Luserkid)
yep its a RHD harness
Old Nov 19, 2006 | 03:33 PM
dohcVTECeg2's Avatar
Default Re: B-SERIES SWAP. HARNESS PROBLEM!! (USDMej1)
flip it
Old Nov 19, 2006 | 04:09 PM
lCHaCHeel's Avatar
how do i get those two plugs to clip in??? if the dont clip on either side?? and i have a pics of the other side driverside tower and theres only two clips so i cant really flip it,or unless im not getting the whole concept of flipping..
(im a dumbass at this moment so is there a way u can explain)
Old Nov 19, 2006 | 05:24 PM
lCHaCHeel's Avatar
i guess there isnt much i can do but get a new harness??
Old Nov 19, 2006 | 06:11 PM
jadugartir's Avatar
If you want plug and play, get a new harness. However, if u want to take it all out of the wire loom and re-route it to be left hand drive, you will prolly need to extend alot of the wires and such but on the bright side all the plugs should work.
Old Nov 19, 2006 | 06:13 PM
Luserkid's Avatar
Default Re: B-SERIES SWAP. HARNESS PROBLEM!! (jadugartir)
See that one piece thats hanging out on the side? That needs to go into your fuse box. Now if you cant plug it in then you have the wrong harness. And for the record that one clip that has all yel/blk wires should have a cap on the end and should not be open to be plugged in.
dapek
Northwest (Sales)
Feb 27, 2010 09:00 AM
JesusGLS
Apr 19, 2007 06:06 PM
3 G's
Oct 4, 2004 05:29 AM
OutLuDeD
Aug 16, 2003 06:30 AM
