Tranny Problem.
Old Nov 19, 2006 | 07:54 AM
b16a4's Avatar
Default Tranny Problem.
Hello everyone,
When i shift from 2nd gear to 3rd gear, SOMETIMES at LOW RPM, the gears grate.
Now MOST of the time, at high rpm, gears grate shifting from 2nd to 3rd.
It also happens when i run the rpm to 8500 in 3rd --> 4th.
What are some of the possibilities, Could one bad tranny mount cause this problem.
Is it the Syncros?
Is It the Clutch Release System [bearings, clutch, slave/master cylinder]
Input Shaft Bearing?
Thank You Very much.
Old Nov 19, 2006 | 12:17 PM
ek_chris's Avatar
It's syncros.
No a bad mount cannot cause a tranny grind.
I would recommend switching to gm syncromesh, see if that helps.
Old Nov 20, 2006 | 07:07 AM
b16a4's Avatar
Default Re: (ek_chris)
also, when the AC is on, i hear a noise from the Gearbox,
when i push the clutch in, it dosent make the noise again....
Old Nov 20, 2006 | 12:55 PM
b16a4's Avatar
Default Re: (b16a4)
anyone?
what about shifter / linkage....
the shifter vibrates too.... it may be touching the exhaust?
Old Nov 20, 2006 | 07:31 PM
igotthaspirit's Avatar
Default Re: (b16a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">also, when the AC is on, i hear a noise from the Gearbox,
Now that sounds like a throwout bearing! But your syncros are worn out as well.
Old Nov 21, 2006 | 06:26 AM
b16a4's Avatar
Default Re: (igotthaspirit)
could it be the input shaft bearing?
Old Nov 21, 2006 | 08:28 AM
Default Re: (b16a4)
doubt it
Old Nov 21, 2006 | 03:29 PM
b16a4's Avatar
where can i get syncros to buy?
whats the cost like.
do i need gears too?
Old Nov 21, 2006 | 04:01 PM
Default Re: (b16a4)
see for your self.
http://www.hondaautomotivepart...SHAFT
Old Nov 21, 2006 | 04:05 PM
b16a4's Avatar
thanks alot bud!....
what illustrated number do i need?
sorry. im a noob to trannys
Old Nov 21, 2006 | 04:48 PM
Default Re: (b16a4)
7 & 8
Old Nov 23, 2006 | 09:12 AM
b16a4's Avatar
are those are sleevs and syncros for 3 / 4 th and 5 / Reverse?
thanx man
Old Nov 24, 2006 | 03:34 PM
Bense's Avatar
1. change trans fluid.
2. check motor mounts
3. check linkage bushings
4. rebuild trans
If one step doesn't fix it, move to the next step until it does.
Old Nov 25, 2006 | 12:15 PM
frostyrb's Avatar
Default Re: (Bense)
I would start by checking the trans fluid level. It could be low & could have caused damage to the trans. I have had a trans make noise & when you push the clutch in it goes away. It was a cracked primary shaft bearing, so if your fluid is low your primary shaft bearings will be the first to go.
97dxred
12
Aug 8, 2008 05:28 AM
95gsr
Jul 17, 2003 04:28 AM
bruthaboost
Apr 27, 2003 02:11 PM
Redelsolguy
Jun 1, 2002 07:53 AM
Lsubball99
Dec 28, 2001 10:43 PM
