stoker kit
Old Nov 18, 2006 | 11:45 PM
chump2825's Avatar
Default stoker kit
is it worth putting in a stroker kit?
Old Nov 19, 2006 | 07:48 AM
R you serious's Avatar
Default Re: stoker kit (chump2825)
since your post really included no important information whatsoever, i thought you might be able to find some better info here..
http://forums.hotrod.com/ubbth...74497
Old Nov 19, 2006 | 08:11 AM
migs's Avatar
Default Re: stoker kit (R you serious)
stok * er
1. a person or thing that stokes.
2. a laborer employed to tend and fuel a furnace, esp. a furnace used to generate steam, as on a steamship.
3. Chiefly British. the fireman on a locomotive.
4. a mechanical device for supplying coal or other solid fuel to a furnace.
Old Nov 19, 2006 | 09:46 AM
chump2825's Avatar
a stroker kit is forged crankshaft..rods..forged piston..wrist pins..rings..locks.acl rod.thurst bearing
is it worth getting
Old Nov 19, 2006 | 10:19 AM
slow_ls's Avatar
Yes it is worth getting. More displacement means you get the much needed torque us honda guys need, and a big bump in horse power. Now if you do this you need to go through the whole head as well with a good PnP job w/ some larger cams to feed the extra displacement. Do not do if you don't have atleast 8 grand for all the work, parts, and possible screw ups probably more like 10 grand. Or if your going to do the work yourself.
Old Nov 19, 2006 | 10:20 AM
slow_ls's Avatar
This should also be in the all motor section.
Old Nov 19, 2006 | 11:14 AM
doood's Avatar
been there done that
Default Re: (slow_ls)
just sleeve and bore for more displacement
Old Nov 19, 2006 | 12:48 PM
MK Ultra's Avatar
For B-series motors, resleeving to a larger bore is a better idea.
Most stroker kits use either a modified B20A crank (note, this is the old Prelude engine, not the 89mm-stroke CR-V B20B/Z motor) or a billet crank.
The long-stroke B20A crank is not as well balanced for high-rpm operation as the B18 cranks, and billet cranks are not as strong as OEM Honda cranks.
Then there's the issue of rod ratio, which is already about as low as one would want in a B-series. Moving the wrist pin up can allow for a longer rod, but at the expense of increased wear on the rings.
IMO, there are just too many compromises involved in increasing the stroke of a B-series.
That money would be much better spent on a resleeve with ~85mm bores.
STATUN'D
Feb 8, 2012 10:24 AM
dc4teg95
Appearance Build Threads
Mar 1, 2010 09:23 AM
Nicks95GSR
Oct 15, 2007 12:55 PM
Fink2iCe
Mar 25, 2005 04:26 PM
Nitto
Sep 14, 2004 08:32 AM
