cranking engine after rebuild - timing problem
i did a complete engine overhaul on my 89 model honda zc. engine is back in and i can't get the ignition timing right...not sure if it is the firing order or the timing or what. pretty sure engine is timed corretl b/c all the marks, crank and cam line up.
suggestions?????????????
there is fuel and fire....pls help!
