Fitting 94-99 GSR Apexi Noir to 97 LS
Old Nov 18, 2006 | 03:35 PM
kwu808's Avatar
Default Help need to Fit 94-99 GSR Apexi Noir to 97 LS
Hi all,
I am trying to figure out how I can fit the Noir to my LS.
so far from my search on HT i've found
the 94-99 gsr header are shorter
the 94+ and ITR have the same header length
the stock cats are all the same size for integra
the obd2 GSR cats have 2 bungs for the o2 sensor
while ls and type r have the primary o2 on the header collector and
secondary on the cat.
i was told to buy a 94-99 GSR cat along with 94-99 GSR header
so now I should be able to bolt on everything (LS cat + Noir) with just 94-99 GSR header, right?
if someone can direct me to a link that I couldnt find I'd appreciated. Thanks
Modified by kwu808 at 8:52 AM 11/19/2006
Old Nov 18, 2006 | 04:06 PM
no2unenolife's Avatar
all the info you've searched is correct.
you would need a gsr cat and header to make it all bolt up.
Old Nov 18, 2006 | 04:53 PM
kwu808's Avatar
Default Re: (no2unenolife)
right.. the o2 sensors are in different spots.. Thanks i missed that part...
so just to clarify ANY GSR cat would do right?
or just 94-99?
no PM functionality yet... hope someone can answer..
Old Nov 18, 2006 | 04:57 PM
make sure its an obd2 gsr cat
i kinda bootlegged it for the meantime since i couldn't find a gsr cat.
i just extended the primary o2 into the ls cat
and just left the secondary o2 out lol.
Old Nov 18, 2006 | 05:06 PM
kwu808's Avatar
im such a noob what u just say? lol
i think ill just buy a high flow cat thats for a 94-99 GSR..
Old Nov 18, 2006 | 05:17 PM
kwu808's Avatar
Default Re: (kwu808)
http://www.car-sound.com/02pro...22639
Old Nov 18, 2006 | 05:28 PM
kwu808's Avatar
and the direct fit high flow cat for a 97 LS is shorter...
http://www.car-sound.com/02pro...22629
can anyone verify that all cats are same length?
xlilninjax
Oct 28, 2010 01:09 PM
lsvtec101
Mar 16, 2009 08:44 AM
Karterguy13
Jan 29, 2005 01:31 PM
DsBananas94LS
Aug 8, 2004 05:48 PM
MugenGTR
Aug 18, 2002 03:16 PM
