egr cleaning clearification
i got code 41 and 12 which is my egr and o2 sensor on my h22. i tried to clean my egr before buying a new one but it still gives me the code. let me know if i did this right.
i bought some carb cleaner and cleaned the egr itself. then i used some seafoam and filled up the two ports( circle and square holes). i put everything back on and started the engine. after that, i ran all the remaining seafoam through the vacuum line. i turned of the engine for five mins. then i restarted and gave it some rev until it clears out from the exhaust. is this how you're suppose to do it? if it was right then i guess i'll buy a new one.
http://www.slhondaparts.com/im...6.jpg
see #42/20? follow the lines to the intake manifold. you'll see the 4 circle caps on the EGR port. pull those caps off and clean out all the carbon build up in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allaboutdaz »</TD></TR><TR><TD CLASS="quote">hiw d we remove those and how do we cap them back up??
can this be done with the manifold on the car??</TD></TR></TABLE>
yes, it can be done on the car. I remember somebody doing a write-up but can't find it. search for under "hesitation" I think or "car not starting". one of those. lol, maybe it was something different. it's been a while.
the caps you should be able to replace. you can get them from the dealership.
tortis
Jul 4, 2015 10:06 PM
Secret Chimp
Nov 3, 2007 04:56 PM
