h22 crankshaft in f22 engine build
Old Nov 18, 2006 | 11:30 AM
TheNosR's Avatar
Default h22 crankshaft in f22 engine build
i have and h22 crankshaft laying around and would like to put it in my f22 i no i will have to use h22 rods but are the h22 bearing the same as the f22 and since the stroke of the h22 crankshaft is shorter i should be able to rev it higher, but since the stroke is short the compression will drop i want the compression to be 10.2.1 like a stock h22 but do you think thats to high. I plan on making it turbo so give me some advice please!
Old Nov 19, 2006 | 07:25 PM
The_Head's Avatar
Default Re: h22 crankshaft in f22 engine build (TheNosR)
It depends on the year of the crank... if it is 98-01 it has a different main bearing size (55mm) than your block (50mm)
go to zealautoworks.com to figure out you're compression ratio. Which head are you using? H or F22?
Old Nov 20, 2006 | 11:47 AM
TheNosR's Avatar
Default Re: h22 crankshaft in f22 engine build (The_Head)
f22
Old Nov 20, 2006 | 01:24 PM
JDogg's Avatar
your compression is going to be really low, shorter stroker lowers compression and there are no pistons with large domes avalible for ethe f22...
keep the f22 crank.
Old Nov 20, 2006 | 02:31 PM
The_Head's Avatar
Did you know the F22 crank and rods are the exact same as the H23's?
Old Nov 20, 2006 | 04:10 PM
TheNosR's Avatar
they do make high dome pistons and i do no that the cranks and rods are the same as h23 im just wondering what bearing to use my crank is from a 94 h22
Old Nov 21, 2006 | 04:41 AM
Oyvind Ryeng's Avatar
Default Re: h22 crankshaft in f22 engine build (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">[...] there are no pistons with large domes avalible for ethe f22...</TD></TR></TABLE>
How about the ones from the F20B?
Old Nov 21, 2006 | 04:46 AM
JDogg's Avatar
Default Re: h22 crankshaft in f22 engine build (Oyvind Ryeng)
you'd have to have the rods rebushed for the floating pin, and the compression height is 1.181 instead of 1.220, so the piston would be way down i the hole.
Old Nov 21, 2006 | 06:24 AM
I see. Thank you for your insight.
popsep3
Oct 2, 2016 11:24 PM
schia89
Jan 3, 2011 04:13 PM
Turbo EH2
May 13, 2008 09:45 AM
honda13typer
Apr 27, 2004 10:04 AM
