engine swap, car starts but wont idle, questions??
Ok I have a 1992 eg hatch with a b18b1 engine, i took the motor out yesterday and when we put it back in and tried to start it, it started but the idle pulses from 1000-1500 like im patting on the gas. Everything is the same as when i took it out (it was only took out and put back in in 1 day)
these are the only 2 things i think that are different than before;
a harness connector that has nothing going to it (didnt notice it before)
then a sensor on the intake manifold i lost the cap so i put a screw in it.
i did not take off the timing belt or distributor.
here are some pics
I am also running open header this time could that be it?
here are some pics
ok i found the cap to that solenoid so i took the screw out, still having the same problem plus there is a check engine light but i do not know how to check the code
a vacum leak would cause a surging problem.....
reset the ecu to clear alll codes........ it could be a grounding problem
grounding an engine is important...
nah that wasnt it, on the back of the manifold 2 of the harness connectors are the same, and i just had them backwards. so i switched them and everything works now. Thank you all for your help
IBriaIN
Feb 10, 2011 05:34 AM
Dyzee
Mar 21, 2004 07:28 PM
