engine swap, car starts but wont idle, questions??
Ok I have a 1992 eg hatch with a b18b1 engine, i took the motor out yesterday and when we put it back in and tried to start it, it started but the idle pulses from 1000-1500 like im patting on the gas. Everything is the same as when i took it out (it was only took out and put back in in 1 day)
these are the only 2 things i think that are different than before; a harness connector that has nothing going to it (didnt notice it before) then a sensor on the intake manifold i lost the cap so i put a screw in it. i did not take off the timing belt or distributor. here are some pics I am also running open header this time could that be it? http://memimage.cardomain.net/member...38_31_full.jpg http://memimage.cardomain.net/member...38_32_full.jpg |
Re: engine swap, car starts but wont idle, questions?? (memorybox)
ok i found the cap to that solenoid so i took the screw out, still having the same problem plus there is a check engine light but i do not know how to check the code
Re: engine swap, car starts but wont idle, questions?? (RJonathan)
its the sensor find a another one and replace it. it probably has a crack on it and causing a vacumm leak
Re: engine swap, car starts but wont idle, questions?? (fmrprojects)
a vacum leak would cause a surging problem.....
reset the ecu to clear alll codes........ it could be a grounding problem grounding an engine is important... |
it is code 14 IACV
Re: (memorybox)
clean it
you need to reajust your base idle using the screw on the throttle body.
Re: (jdm_eg06)
His idle is surging so probably not. Clean the IACV and if that does not fix it look for vacuum leaks. Also check to make sure you hook all of the lines up.
Re: (spoonracer84eg)
When my throttle body gasket was messed up my idle would surge.
just a tip. |
Re: (La-Quiete)
nah that wasnt it, on the back of the manifold 2 of the harness connectors are the same, and i just had them backwards. so i switched them and everything works now. Thank you all for your help
