What fuel line do I check?
I have a 94 LS integra that wont start. I checked the battery and it is getting power. Lately it has been taking an extra second to turn over when I start it so I was thinking I just needed a tune up. Then I drive it to lunch and when I get off of work it won't start. Now I'm wondering if the fuel pump has died. So my question is which fuel line do I check to see if I'm getting fuel pressure? This is my daily driver and I need to get her fixed. Thanx
Modified by TexasluvsHondas at 11:43 AM 11/21/2006
Yeah I know. I'm here with a stranded car and I need to figure out what is wrong with it so I was asking how to find a fuel line that will tell me if my fuel pump just died or not.
You can pull a plug wire and use an old spark plug to see if it is throwing a spark. There is a banjo bolt on top of the fuel filter to see if the system is pressurizing with fuel.
That's what I did. I pulled the bolt on top of the fuel filter and it was getting fuel. Whe I pulled a plug wire and used aspark plug it wasn't getting any spark. I took the distributor apart and cleaned it and still nothing. Is the distributor wasted or what?
Christopherian1982
Dec 31, 2008 08:17 AM
