something to put between rod bearing and rod? :)
Old Nov 18, 2006 | 06:40 AM
ej2civic's Avatar
Default something to put between rod bearing and rod? :)
OK, picture tells more than 1000 words
Old Nov 18, 2006 | 09:52 AM
mmuller's Avatar
Mad Scientist
Default Re: something to put between rod bearing and rod? :) (ej2civic)
clean with preferebly a crosshatch (rod end) and lightly coat with oil
Old Nov 18, 2006 | 11:38 AM
ej2civic's Avatar
Default Re: something to put between rod bearing and rod? :) (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">clean with preferebly a crosshatch (rod end) and lightly coat with oil</TD></TR></TABLE>
Ok thanks you very much
Old Nov 18, 2006 | 12:00 PM
mec. pedri's Avatar
the rod should be clean
lubricate the bearing and rod journal
i never lubricate behind the bearing
Old Nov 18, 2006 | 12:11 PM
clayne's Avatar
Default Re: (mec. pedri)
You mean something to clean it with? Use carb or brake cleaner, make sure the surface is absolutely dry and not lubricated.
Old Nov 18, 2006 | 12:34 PM
mmuller's Avatar
Mad Scientist
Default Re: (clayne)
drill wire brush works great, you can get a light crosshatch with it also
Old Nov 18, 2006 | 12:44 PM
clayne's Avatar
Default Re: (mmuller)
Why bother marring the surface when proper cleaning suffices?
Old Nov 18, 2006 | 01:44 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayne &raquo;</TD></TR><TR><TD CLASS="quote">Why bother marring the surface when proper cleaning suffices?</TD></TR></TABLE>
personal preference, if you can improve on things; why not.
No marring, light crosshatch pattern should i say. just like oem
Old Nov 18, 2006 | 09:42 PM
Duane_in_Japan's Avatar
The crosshatch on the rod big end is not for cleaning, it was for resizing then honing, do not take any more metal away. Do not lube behind bearing, use an assembly lube on the crank journals. If you like you can get some plastigage and check the oil clearances on all of your journal to bearing surfaces, ask the autozone guy for plastigage. If you do not want to buy assembly lube then oil will be fine but disable fuel and crank the engine for a bit to prime the oil throughout the engine before starting your fresh rebuild with no oil pumped through it yet.
Master Tech with many years of engine rebuilding (back in the day, back in the US)
EDIT:
You can also dip the piston into a coffee can of hot oil to prelube the wrist pins, move the pistons about a bit to get oil into the wrist pin to piston area similar to what you thought you were supposed to do with the rod big end. Wipe the piston top to clear off as much oil as you can the lower smoke time on startup.
Old Nov 19, 2006 | 07:24 AM
mmuller's Avatar
Mad Scientist
Default Re: (Duane_in_Japan)
i DO NOT mean take material out. Drill wire brush brush WILL NOT take material nor cause marring on the rod .
Crosshatching big rod ends has a benefit which im not going to get into .
different build preferences does not mean its wrong, different strokes for different folks..
Old Nov 19, 2006 | 07:34 AM
white90rexsi's Avatar
The wire brush IS removing metal from the rod. Depending on your clearence, it could creat extra clearence and create a problem
Old Nov 19, 2006 | 07:43 AM
mmuller's Avatar
Mad Scientist
Default Re: (white90rexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90rexsi &raquo;</TD></TR><TR><TD CLASS="quote">The wire brush IS removing metal from the rod. Depending on your clearence, it could creat extra clearence and create a problem</TD></TR></TABLE>
omg. have you tried it or your just thinking it will? i have been doing that for long. try it youll see. You obviously have to use common sense and use a SOFT wire brush.
the crosshatch that im talking about is not like cylinder crosshatch.
I use a wire brush to get carbon off combustion chambers and valves.. go figure i must be ******* some serious shiiet up.
Old Nov 19, 2006 | 07:54 AM
Im not saying it will mess it up, I am saying that using a wire brush is removing metal. I took a cylinder block service class last semester and they went through reconditioning rods and never once did they use a wire brush on a drill. We always used denatured alcohol with some lint free shop rags, that always cleaned them up great.
Also the valve face is not a precise area, such as a rod.
Old Nov 19, 2006 | 11:06 AM
clayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">You can also dip the piston into a coffee can of hot oil to prelube the wrist pins, move the pistons about a bit to get oil into the wrist pin to piston area similar to what you thought you were supposed to do with the rod big end. Wipe the piston top to clear off as much oil as you can the lower smoke time on startup.</TD></TR></TABLE>
Funny, I read the above as: "also you can dip the piston into a cup of hot coffee to prelube the wrist pins."
Probably due to my subliminal need for coffee this morning.
Old Nov 19, 2006 | 11:07 AM
clayne's Avatar
I use a wire brush to get carbon off combustion chambers and valves.. go figure i must be ******* some serious shiiet up.</TD></TR></TABLE>
Yep, even though I only use a topical cleaner - there is no way that a soft wire brush is taking off enough metal to change clearances significantly.
Old Nov 19, 2006 | 11:20 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90rexsi &raquo;</TD></TR><TR><TD CLASS="quote">Im not saying it will mess it up, I am saying that using a wire brush is removing metal. I took a cylinder block service class last semester and they went through reconditioning rods and never once did they use a wire brush on a drill. We always used denatured alcohol with some lint free shop rags, that always cleaned them up great.
Also the valve face is not a precise area, such as a rod.</TD></TR></TABLE>
seriously just because they did not use a wire brush on the rods, it does mean its wrong. plenty people do it this way.
i dont think you understood what i ment about using a wire wheel on chambers and valves.
i clean the whole valve with a wire wheel, and the chambers that well are Aluminum and with your reasoning they should get reaaally chewed up with the wires..
Old Nov 19, 2006 | 12:17 PM
Garage 808 Hatch's Avatar
i would put nothing there. the bearing does not spin on the inside of therod, it moves on the crank
Old Nov 19, 2006 | 02:37 PM
B e v - T e c h I n c.'s Avatar
DON'T USE ANYTHING!!! just clean it, and put the bearing in, if you lube it up, it's asking for trouble...
Old Nov 19, 2006 | 03:08 PM
mmuller's Avatar
Mad Scientist
Default Re: (B e v - T e c h I n c.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B e v - T e c h I n c. &raquo;</TD></TR><TR><TD CLASS="quote">DON'T USE ANYTHING!!! just clean it, and put the bearing in, if you lube it up, it's asking for trouble...</TD></TR></TABLE>
care to explain?
damn everyone likes to argue here
Old Nov 19, 2006 | 03:39 PM
s10cky's Avatar
This is why some peoples motors seem to last longer than others.
Old Nov 19, 2006 | 04:04 PM
clayne's Avatar
Default Re: (s10cky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">This is why some peoples motors seem to last longer than others. </TD></TR></TABLE>
I'd say it has more to do with paying attention to detail rather than a particular method.
What mmueller said about his method isn't that much of an issue and won't harm anything - it's just what he prefers. But by no means is it going to create an unreliable engine.
Old Nov 19, 2006 | 05:00 PM
mmuller's Avatar
Mad Scientist
if you dont have anything constructive to add, stay out of this.
care to explain why this comment?
Old Nov 19, 2006 | 05:29 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Seen muller build ****.. he is a perfectionist and everything is done right it is also very reliable... maybe sometimes people should just listen and stop being stubborn
Old Nov 19, 2006 | 08:45 PM
Default Re: (DBL)
If you put oil behind the bearing from the start you will escentially create a small shim (of oil) and push the bearing closer towards the crank journal, this will give less of an oil clearance for normal oil pressure to lube the rod bearing where lube is needed. If you installed a new cam, your engine will not see idle for many minutes, you have to break in the cam, fast.
This is another reason to use plastigage and insp oil clearance prior to final assembly, it is also a guide to tell you if clearance is too great that you need to turn the crank and use undersize bearings (.010 under).
When you wipe the back of the new bearing dry and the rod big end dry do not wipe the protective grey (?) coating off of the face of the new bearing, it is a 'brake in' coating.
Most folks measure in 1 thousanths of an inch .001, I use 10 thousanths .0001 so I like to be sure, ultimetly most items .001 out of spec (or less) is allowable.
Its true, a new clean engine with proper clearances and a good break in lube and proper oil priming prior to start up, proper cam break in procedure, quick oil and filter change, proper ring break in procedure and the list goes on and on will make for a better rebuild. Keep the garden hose near by to top off the radiator so the air bubbles can escape a little better by having that extra inch of water (static) pressure to assist with bleeding.
Old Nov 20, 2006 | 04:49 AM
clayne's Avatar
Default Re: (.EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I've never seen a used rod where the original crosshatch from the original hone was not visible.</TD></TR></TABLE>
You're kidding right?
